» Site Navigation
» Other Sites
Old 02-28-2006, 11:35 AM   #11 (permalink)
Date registered: Aug 2005
Vehicle: 2002 E320 Wagon
RE: Ok to use ramps to raise e320, recommendations?
Thanks for pointing that out. I should be able to put the ramp behind the left rear tire and backup on it, tipping the car in that direction.
87path is offline   Reply With Quote
Old 03-03-2006, 10:19 AM   #12 (permalink)
Date registered: May 2005
Use a Topsider to remove the oil from the dip stick line. No under car work needed.
Zill is offline   Reply With Quote
Old 03-04-2006, 04:30 PM   #13 (permalink)
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 00 E320
Maybe I'm doing it wrong, but I have been using a Topsider (actually an Oil Boy) and I think it isn't getting the last quart out[:(!]
I carefully try to bottom the plastic tube, but when refilling -- imagine my shock when I'm topped out on the dipstick at 7 quarts[:0]
Has anyone had experience with the adjustment needed (lift a side, etc) that might make this work better?
I guess I can deduce that the dipstick is on the right side, so if I lift the left side..... but I would like experience if anyone has it
Mike
Now: 2000 E320, Then: 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline   Reply With Quote
Old 05-08-2007, 12:54 PM   #14 (permalink)
slybydesignw210's Avatar
Date registered: Jan 2007
Vehicle: Pearl White 1994 Q45T
Does top siders work? how much are they?
slybydesignw210 is offline   Reply With Quote
Old 05-08-2007, 01:23 PM   #15 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
I bought one for the Jetta, and used it for the E300 about a week ago. I paid just over $50 (with shipping) from West Marine.
It did work, and got as much oil out as does using the drain plug (based on the volume in the pan), but it took what seemed like forever. Well over an hour. I had to repump the thing a few times.
I can't say if I recommend doing it this way or not yet. I'll have to try it a second time to see what I think about it, as it's not really all that easy to do it from underneath.
Old 05-08-2007, 01:37 PM   #16 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
Thumbs up
I have a set of ramps. I only use them for odd jobs. I use the top sider for oil changes. It's clean and quick and you never get on the ground.
E430 Sport
2001 E430 in Desert Silver with Sport Package, COMAND, Xenon Lights, Rear Sunshade, Heated Seats. Added K40 Stealth Radar, 30% Tint, XM Radio! www.premierbasement.com
acarter53 is offline   Reply With Quote
Old 05-09-2007, 10:25 AM   #17 (permalink)
Oh so you use a top sider? wow......talk to me I'm interested, this might be my answer, but is there any benefits or down sides with top sider, can you give me a side by side comparison like a drain plug oil change verses top sider?
Old 05-09-2007, 10:36 AM   #18 (permalink)
Premium Member
acarter53's Avatar
Premium Member
Well,
I use it b/c
1) I do not have to jack up the car.
2) I don't have to remove the under shields
3) I don't have to get on the ground at fight with the drain plug.
4) The oil gets sucked out and I just take the unit to a shop and dump it.
5) No mess.
6) Most Dealers use it.
7) I can measure how much oil I remove.
The Down side (Some say) you do not get the stuff that sets on the bottom of the oil pan out.
Old 05-09-2007, 10:53 AM   #19 (permalink)
now with that being said, cant that help when particals are draining verses being pumped out and up. just wondering?
Old 05-09-2007, 11:12 AM   #20 (permalink)
Premium Member
acarter53's Avatar
Premium Member
Cool
I don't know . I feel that if I use the fleece filter, it should protect the engine from anything that I can not pump out. The dealers does it this way all day long with cars the are worth much more than mine. I do not think that they would risk buying a new engine for a S 55 or CLS 65 if this was not a good method for changing oil. But at the end of the day its all about what you feel is best for your car. My $0.02 worth.
