» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 02-12-2006, 02:07 PM   #1 (permalink)
Date registered: Feb 2006
Vehicle: 1998 E320
suspension bumping/rattle noise
Any suggestions on where my noise is comming from. I just purchesed a 98 E320, 95K miles. While driving over small bumps or slowly over a rough section I hear a bumping/ rattle coming from front right side. Sounds like a loose sway bar, but upon inspection all "?seems?" tight> shocks, spring,exhaust,sway bar. There is no noise while pushing on fender and there are NO squeeks...just sounds like someone is lightly tapping on passanger floor board with a hammer??????????????????
Thanks,
S
sarmstrong is offline   Reply With Quote
Old 02-12-2006, 04:27 PM   #2 (permalink)
Date registered: Dec 2004
RE: suspension bumping/rattle noise
I have the same noise. Am taking it in this week. Will let you know what it is.
I suspect mine is a worn sway bar link, shock mount, or exhaust rattle.
lexrex is offline   Reply With Quote
Old 02-12-2006, 07:16 PM   #3 (permalink)
Vehicle: W210 E300TD
I had the same thing, 2 new links and it was gone. Cheap as well.
Parrot of Doom is offline   Reply With Quote
Old 02-12-2006, 11:20 PM   #4 (permalink)
Vehicle: 1998 E320
Yes, please let me know what you find out and I willhave the same thing checked on mine
Thank You!
Old 02-13-2006, 09:13 PM   #5 (permalink)
Date registered: Oct 2005
just did 2 new links,and replaced the actual swaybar bushings as well.no more noise at all total of 30 min. to install and 40 bucks for all the parts.
gikser is offline   Reply With Quote
Old 02-15-2006, 05:28 PM   #6 (permalink)
Mine turned out to be a bad shock absorber. Unfortunately, parts & labor for the 4Matic front shocks are $$$.
