Old 02-04-2006, 08:34 PM   #1 (permalink)
Sandro N's Avatar
Date registered: Feb 2004
Vehicle: Hooked up 96 E320
Broken Ignition cylinder, Cant turn key, Any Help???
Recently I gave the guy at my body shop the valet key to start my benzo while in the shop. When I picked the car up, I tried to start the engine with my regular IR key (switch blade type) but found it very dificult to turn the cylinder, It takes some real good giggling around.
There seems to be something broken down inside the cylinder, its becoming harder and harder to get the ignition to turn. Am I in big trouble here? any help would be greatly appriciated.[?]
sandro natale
Sandro N is offline   Reply With Quote
Old 02-05-2006, 01:13 PM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: Broken Ignition cylinder, Cant turn key, Any Help???
You are probably going to need to have it replaced before it will not turn at all. I had this happen to a 190E. Eventually it snapped when I turned the key and stayed in the accessory position. I could not get the key out or start the car. With the W210 E-Class, they can pull just the tumbler section out with a special tool and check it out. If they find pieces of metal inside, they will have to replace the cylinder or ignition switch assembly.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
