| RE: left side door mirrow Are you changing the cover, glass or the whole mirror?
You can fold the mirror back against the door and use a flat screw driver to pop the clip that hold the cover on. It slides off over the mirror glass.
The whole mirror is held on the door with 3 screws in a triangle pattern at the base.
The mirror glass has a wire clip on the back that holds it to the mirror motor.
Hope this helps.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors. |
