Hi Guys, I'm James from England - in my late 70's and feeling very, very sick!! [:(]
Bought E200T, 1997, W210,(StationWagon) last year,
on 'EBAY' (Biggest mistake of my life) [:(!]
and have had dire problems ever since...
Been in industrial electronics all my life, but this one has me stumped... [?]
Last week, noticed that the indicator lamps did not flash when unlocking /locking the car - but the central locking system opened /locked all doors and tailgate.
The car started OK - Instrument Cluster background lighting worked and SRS indicator lamp showed On/Off
as normal -
BUT,
NO watertemp/ fuel/ speedometer/ rev counter gauges
or any of the small indicators/ charge/ bulb failure/
hi-beam / brakes, etc. etc.
No hazard flashers, windscreen wipers or water jets,
No direction left/right indicators / or small side lamp indicators.
No horn.
No interior heater Fan
Still WORKING OK are:
Headlamps /Hi-Lo beam, dipping and flash, OK
Rear lamps/stoplamps/ reversing /foglamps, OK
All interior lamps / fade down and off, OK
Adjust wing mirrors/ Radio/ cigarlighter, OK
Slide/tilt sunroof, doorwindows up/down, OK
Starter/ alternator/ battery charging, OK
Car starts normally, BUT, gearbox changes feel different - car normally coasts down hills smoothly
BUT NOW car slows when throttle pedal is released and car slows down similar to a manual gearbox car with engine braking effect.
I've triple checked every fuse in the four fusebox, both for voltage continuity in-situ and individually
for resistance continuity when out of fuseboxes.
Also, checked relay in fuse cluster in battery compartment under rear seat. OK
It would seem perhaps a relay has failed but they are difficult to locate and lack of wiring diagram makes it almost impossible to trace circuitry.
At this stage I'm baffled and have serious problems to get the car to the nearest Merc service dealers,
(about 15 miles away)
1/ I could drive the car - But with NO indicators, horn, hazard flasher,windscreenwiper or speedometer,
is both Foolish and Illegal - and I could land up in serious trouble in more ways than one !!!
2/ Official Merc service over here equates to some
$200 per hour - And Senior Citizen State Pension over here is less than that per week !
Gentlemen, I would seriously welcome any positive indication or inspired guesses of where to look for possible source of the problem.
From Jim Steadman:
Gentlemen, I omitted a postscript to the above posting - Last year, shortly after aquiring the car from a Charleton on EBAY (who has now been banned)
I joined this forum and posted a request for information which included changing the clock display
bulb - several kind Folk replied with positive information - unfortunately my laptop was stolen
and all my contacts and references went with it.
To the Gentlemen who replied:
I Belatedly Thank You All for Your Courtesy...
