Old 01-31-2006, 08:48 PM   #1 (permalink)
riz
Date registered: Apr 2004
Vehicle: 99 E320 wgn 4matic
panel cover ?????
Does anybody know how to remove the panel cover below the steering shaft? I need to access/replace the cable for foot brake release. I think the cable snapped.[:0]
Thanks in advance.[8D]
riz is offline   Reply With Quote
Old 02-01-2006, 09:26 AM   #2 (permalink)
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230 Kompressor 2000 year, Brabus Monoblock VI, 15mm spacers, Eibach Pro Kit, Flat emblem
RE: panel cover ?????
riz
I had to replace the brake switch which is in the same place as your footbrake cable and I posted a procedure which included how to remove the panel.....
To remove the underside of the drivers panel:
There should be 4 Phillips screws you need to undo first.
1 near the bonnet release.
2 near the front the opposite side to bonnet release.
3 underneath in middle
4 at the back above pedals.
With these screws removed you need to pull the tray towards you as there are clips on the front under steering wheel. Then near the centre console you need to pull downwards as there are 3 clips there also. That should be it!
Takes about 2 mins.
....all the best A1EK
A1EK is offline   Reply With Quote
Old 02-02-2006, 03:32 PM   #3 (permalink)
riz
I'll try this out. Thanks![:)]
