Old 01-31-2006, 05:23 AM   #1 (permalink)
Date registered: Oct 2004
Send a message via Yahoo to nkhimani
Poor MPG - 1999 E300TD
Hello,
I recently noticed that MPG have dropped off by almost 5-7. No light on the dash. No loss of performance (at least none that I can notice). Recently changed all the filters. There is some VERY minor "oil leak" near return air manifold (EGR stff?) that loops back on the driver side.
Tire pressure is okay, no fuel leak of any sort. Will appreciate any pointers/suggestions. I did change the brand of diesel fuel as well. Thanks in advance.
-NK
nkhimani is offline   Reply With Quote
Old 01-31-2006, 06:32 AM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
RE: Poor MPG - 1999 E300TD
What did the mileage drop to and that is based on how many tanks of fuel?
Len
sokoloff is offline   Reply With Quote
Old 01-31-2006, 06:49 AM   #3 (permalink)
From ~32 MPG to about ~25MPG.
So far six tanks ...
Old 01-31-2006, 09:02 AM   #4 (permalink)
Vehicle: W210 E300TD
Possibly failure of a lambda sensor? Might be an idea to put a diagnostic on the port, see if theres any codes.
Parrot of Doom is offline   Reply With Quote
Old 01-31-2006, 12:33 PM   #5 (permalink)
AlanMcR's Avatar
Vehicle: 96 G300DT
Most likely a combination of winter fuel and more cold starts. If you have a lot of miles on it and poor oil change intervals it is possible that the timing chain is wearing, but that would happen ever-so-slowly.
Parot-of-doom: there is no lambda sensor on the diesels. They always run a lean exhaust. Perhaps you meant the air mass sensor (on the intake). Failure of that part leads to a dramatic loss of power.
...Alan
63 230SL
96 G300DT
98 E300DT
AlanMcR is offline   Reply With Quote
Old 01-31-2006, 01:15 PM   #6 (permalink)
Hmmmm ...
I have been driving diesels since 1989 ... Winter blend (Kerosene) has rarely messed-up MPG and neither has cold start. As a matter of fact, diesels (all IC engines for that matter) run much better (efficient) in cold weather (denser air mass) than in summer.
Oil changes have been like a clock work @ 3k. Like I said, the only abnormality that I have observed is a very tiny oil leak that is near a sensor on return air manifold (?). Again, thank you all for suggestions/ideas. It is much appreciated.
