Old 01-29-2006, 06:45 PM   #1 (permalink)
97 E420's Avatar
Date registered: Jan 2004
Vehicle: 1997 E420
Fog Light Removal?
I just bought a set of Projector Headlights and Foglights and read through the thread about taking out the Headlights. I wanted to see if anyone has changed their foglights and how much of a procedure it is? Any info would be appreciated.
97 E420 is offline   Reply With Quote
Old 01-30-2006, 05:47 AM   #2 (permalink)
Godiva's Avatar
Date registered: Jul 2004
Vehicle: 2005 E320 4matic S/W
Send a message via AIM to Godiva
RE: Fog Light Removal?
I, too, just purchased projector foglights - will try to install them this week provided I get all my Super Bowl prep done - so would be interested in others' experiences. Changing out the bulb was a pain in the ass, so I am hoping once the car is up I can just just pull out the whole unit & replace like a plug & play.
1959 300SL Roadster - dad's baby
2002 E320 4matic S/W - it was a great car
1998 C320 - daughter's ride
2005 E320 4matic SW - my current
2007 GL CDI - family workhorse
Chevy muscle cars - hubby's hobby
Godiva is offline   Reply With Quote
Old 01-30-2006, 10:51 AM   #3 (permalink)
raymond-'s Avatar
Quite easy a task ....if you have short forearms and
constructed like Gumby and no lift.
Reasonably simple if you use a floor jack to lift the
side you're working on at least 6" or more.
Open hatch beneath bumper/fog lamp.
Reach in and unplug electrical connection (if you can).
Unfasten single bolt which is located along the side of
the housing...closest to centerline of car.
Above the top of the lamp housing are two locater pins
along the top corners of the lamp, and which mate to
sockets on the car. I recall they were rubber sockets.
Carefully (!) wriggle the housing free and tilt
sideways. Lower and out the hatch door.
If the wiring is still connected, be careful...and
once you can see the plug/socket, you can wedge it
free. A small flat blade helps.
Reverse to install.
Good to point out that it might help to spritz a shot
of silicone on the locator pins of the new lamps.
Why? If aftermarket, these pins can be a weak point
and can break off if you are inserting them into the
locator sockets. The silicone eases the effort
tremendously.
Caution: aftermarket light may also be weak in the
spiral gearing tolerance. You may want to test this
out and to ensure full travel while in hand.
Socket with extension helps.
Needle nose pliers helps.
Small flat blade helps.
Time: 30 mins for the first one.
5-10 for the second one.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 01-30-2006, 05:17 PM   #4 (permalink)
Sandro N's Avatar
Date registered: Feb 2004
Vehicle: Hooked up 96 E320
so true, I just got a pair. these fogs are a pain to adjust.
sandro natale
Sandro N is offline   Reply With Quote
Old 01-30-2006, 06:01 PM   #5 (permalink)
97 E420's Avatar
Vehicle: 1997 E420
Thanks for the info Raymond !!!
I just got my foglights in the mail today from CA (I live in NY) and one of the white adjustor assemblies were in the bottom of the box rolling around !
Does anyone know if they are broken or if they pop back into place.....it appears that they are broken as they will not set back into the housing !!
I am soooo Fin pissed off because last week I received my Projector lights and 1 of the projector anchors were cracked and rolling around in the assembly !!!! I had to send them back for an exchange. It appears that I will be sending these Fin foglights back too !
Old 01-30-2006, 06:19 PM   #6 (permalink)
Mr. Pie's Avatar
Date registered: Nov 2004
Vehicle: CLK320 / E500
Send a message via MSN to Mr. Pie
When someone gets them instaled I would really like to see some pics. I would like to swap those out on both my w210 and w208.
2001 W208 Black Opal Metallic
K2a, K3, K4 + COMAND, HID halo projector headlights, flat hood emblem, chrome cluster rings, Bluetooth phone adapter, MB illuminated door sills, AMG steering wheel, AMG pedals, chrome AMG II dual spoke wheels, Nitto NT 555 Extreme Performance, 235/35/19 front, 265/30/19 rear
2004 W211 Platinum Blue Metallic
Premium Package, Apperance Package, Keyless Go, Bluetooth puck and tail
Mr. Pie is offline   Reply With Quote
Old 01-30-2006, 08:58 PM   #7 (permalink)
Date registered: Jan 2006
If someone has upgraded and would like to sell the original one I am looking for one to replace in my 1996 e300.
I have found the replacment lense online, but if someone has a complete lamp, so much the better.
Thanks
Mike
nozzano22@yahoo.com
nozzano22 is offline   Reply With Quote
