Old 01-29-2006, 06:28 PM   #1 (permalink)
Date registered: Jan 2006
Electric windows, mirror & trunk release from console problem
I have a 99 e320 which has just developed a problem. It is not a fuse. All four windows are closed and will not work with any of the center console switches or rear door switches. However, all windows will open using the remote key feature and holding the unlock button down and will also close the same way. the mirrow will move when using the three memory keys on the driver door but will not move using the console switch. The trunk release works with the electronic key opener but the console switch will not work (and is not lit). I was wondering if anyone has ever had this or a similar problem. Please let me hear from any one with a suggestion. i have tried to post this message once before and am not sure it went through. Sorry if there is a duplication of this post.
digger99e320 is offline   Reply With Quote
Old 02-04-2006, 02:38 PM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: Electric windows, mirror & trunk release from console problem
I would replace the switch module that is under the wood base around the shift knob. It sounds like it is faulty. The child lock switch for the back window switches is in this module along with the mirror controls, trunk release and the window switches. I would check to see that it is plugged in first. The wood piece can be lifted along the edge that meets the cup holder door. The ring around shift module will snap up as well. The switch module mounts to the back of the wood panel. The cables that plug in to it are just below the mirror control. What happens is that a drink in the cup holder gets spilled and it shorts out the switch module.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 02-04-2006, 05:31 PM   #3 (permalink)
Thanks, I will try that and let everyone know.
Old 02-04-2006, 11:18 PM   #4 (permalink)
Vehicle: 2001 E320 2WD
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
E-Klasse,
Always trying to help others! Many people will appreciate your inputs and information. I certainly do.
Raylee177 is offline   Reply With Quote
Old 02-05-2006, 03:06 PM   #5 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Date registered: Jul 2004
Vehicle: SL, CLK & 5E's
Raylee177 - 2/5/2006 6:18 AM
E-Klasse,
He taught me almost everything I know about the W210.[:I]
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/41571.gif"border=0>
<img src="http://www.danasoft.com/vipersig.jpg">
Storm. is offline   Reply With Quote
Old 02-05-2006, 05:46 PM   #6 (permalink)
Ruffrob's Avatar
Date registered: Jan 2004
Vehicle: 2003 Obsidian Black E320
Send a message via AIM to Ruffrob Send a message via Yahoo to Ruffrob
E-Klasse,
Definitely.....[8D]
1997 Black E320
1994 Black Acura Legend L (gone,but not forgotten)
Ruffrob is offline   Reply With Quote
Old 02-05-2006, 07:10 PM   #7 (permalink)
raymond-'s Avatar
digger...
you didn't spill a drink onto the console, did you (or someone)?
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
