Old 01-23-2006, 12:53 PM   #1 (permalink)
Date registered: Jan 2006
Where is the Horn Fuse?
I called the dealer and they suggested coming and letting them look. Easier for them. However, not for me. I have read the list a bunch of times. Everything works. Except the horn.
I took it out and connected it directly to a battery and it still doesn't work. Its toast.
Now looking for a horn also.
jeff338 is offline   Reply With Quote
Old 01-24-2006, 09:02 PM   #2 (permalink)
skipinschool's Avatar
Vehicle: 98 E-430 (W210)(RIP) 96 S600 (W140)
Send a message via AIM to skipinschool
RE: Where is the Horn Fuse?
hey... if you have a horn problem, i have about 20 of those horns laying around for sale [:D].
I manage a salvage yard and i have PLENTY of parts from the E-class (body style W210. On my signature is my number..... My name is Dominik, and i can get you a good deal on parts your looking for.
P.S. i have that same problem, but i never bothered to look into it.
if you find out that your horn does work... then it might be a problem with your clock spring in between the steering wheel and the airbag.
skipinschool is offline   Reply With Quote
Old 01-25-2006, 06:26 AM   #3 (permalink)
Date registered: Oct 2005
I HAD THE SAME PROBLEM AND FOUND A FUSE UNDER THE HOOD ON THE RIGHTS SIDE FENDER AREA WHERE THE ECU IS AT YOU HAVE TO REMOVE SOME PHILLIPS HEAD SCREWS ON THE ACCESS COVER AND THE FUSE IS UNDER THERE.
gikser is offline   Reply With Quote
Old 01-27-2006, 06:39 PM   #4 (permalink)
Franasia's Avatar
Date registered: Jan 2005
Vehicle: 2000 E320S4 210.282
jeff338 - 1/23/2006 2:53 PM
There are two fues for the horns: Nos. 40 + 41. They're located in the fuse box next to the master brake cylinder.
When I first got my current E320, about a month and a half ago, only one horn was working. It was not a fuse problem but the horn itself. They use these very cheese horns nowadays that don't seem to last very long. I replaced them both with a set of Hella Supertones and I'm very happy with them. They have the much more classic Mercedes tone and are also quite loud.
Hope it helps.
“Design embodies the values of a company. Even if there were no star, the car must always be recognizable as a Mercedes-Benz.” Peter Pfeiffer, Daimler AG
Franasia is offline   Reply With Quote
Old 02-02-2006, 03:13 PM   #5 (permalink)
FYI, I was near a dealer and stopped. The horn is not called a horn on the fuse chart. It is something really strange I cannot even remember now. Something like Declare or Announce. I have only one horn, directly between the two cooler fans in front of the radiator. Mercedes wanted about $80. I found one at Pep boys for $20. Works fine. (The mercedes horn was shorted. apparently a common problem.)
Old 08-05-2006, 01:25 PM   #6 (permalink)
JP1
Date registered: Nov 2005
Vehicle: 2002 E320
It's called "fanfare" on the fuse chart, fuses #40 and 41. I just came from the inspection station and my horn didn't work. We couldn't find horn on the fuse list and couldn't figure out why it didn't work. Luckily he passed my inspection on the promise that I'd fix the horn. Thanks to this forum I found it was just the fuse. I never would have found that fanfare fuse.
JP1 is offline   Reply With Quote
Old 11-07-2008, 09:25 AM   #7 (permalink)
arneleo's Avatar
Date registered: Dec 2007
Vehicle: 2002 E55 AMG
W210 E Class Horn Fuse
It's the 10 amp red fuse on the top right corner of the photo, just above the 15 amp blue. It should say 40 next to it.
Hope it helps.
E55 AMG Tectite Grey
GS300 Silver Sport
arneleo is offline   Reply With Quote
