Old 01-16-2006, 02:36 PM   #1 (permalink)
Date registered: Apr 2005
Vehicle: 1998 MB E430
98E430: Bad Vibration When Idle
The whole car vibrates when the engine idles. It's especially bad on Reverse. Neutral vibrates, but it's slightly better. Drive idle is almost as bad as Reverse. Could this be a mount problem?
The car sounds fine at RPMs past around 800 or so. Problem is, the idle stays around 500. I put the tranny on N at traffic lights to slightly alleviate the vibrations.
All comments/suggestions/advice welcome.
Thanks.
4.3 Liter
4.3Liter is offline   Reply With Quote
Old 01-16-2006, 04:29 PM   #2 (permalink)
Guest
Posts: n/a
RE: 98E430: Bad Vibration When Idle
Bad Harmonic Balancer?
Have you had the recall performed by your dealer? You definitely don't want to run the car if the balancer is bad - unless pieces of engine internals on the ground sounds appealing! Good luck.
Old 01-16-2006, 04:45 PM   #3 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
if you search this board, you'll prob find other references
to the HB recall. too lazy to search but I did PDF them
for my brother - should be the same info previously posted.
http://waltermitty.net/mb/TSB/hb.pdf
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 01-17-2006, 12:08 PM   #4 (permalink)
Thanks, Walt...
I'll check into that.
Old 01-17-2006, 02:37 PM   #5 (permalink)
Double0hE55's Avatar
Vehicle: 2000 E55, 2002 WRX
Send a message via AIM to Double0hE55 Send a message via Yahoo to Double0hE55
Also take into considertation of motor mounts. I just recently found out that my motor mounts are blown out. and my car shakes at idle.
19 Polished Brabus Monoblock V
Vogtland Springs #3 Spring Pad
Koni Adj Shocks
Double0hE55 is offline   Reply With Quote
Old 01-17-2006, 04:33 PM   #6 (permalink)
Guest
Posts: n/a
I had the same problem on my car, and was told that it was the motor and transmission mounts.
