Old 01-09-2006, 10:21 AM   #1 (permalink)
Date registered: Feb 2005
Vehicle: E320 2002
awful sound from dash
Hey Guys,
I have this awful high pitched whistle that's coming from my dash, which stops when I turn off the fan. Does anyone know if this is the fan or some seal that is not tight? Is the fan difficult to get too and is it expensive. Will a quick squirt of WD40 help or make the problem worse?
Thanks in advance, you guys are great!
skorny
skorny is offline   Reply With Quote
Old 01-09-2006, 11:01 AM   #2 (permalink)
JG
Date registered: Feb 2003
Vehicle: '00 ML430, '97 E320
RE: awful sound from dash
I am having a similar problem with my 97 E320 except I would describe my sound more like a fast chirping (I guess whistle is a good term too, but not real high pitched). It does not vary a whole lot with fan speed but definately goes away when the fan is turned off. The weird thing is that the noise comes and goes with no real consistency. Hopefully someone will respond with a possible solution.
JG is offline   Reply With Quote
Old 01-09-2006, 02:28 PM   #3 (permalink)
Date registered: Jul 2004
Vehicle: 2000 E320 4MATIC
Guys,
This sound is coming from your AC fan, you just have to change resistor that attached to your blow motor fan. I fogot the actual name of this part, check with your local Mercedes parts store, they will know. I had the same problem on my 2000 E320. Good Luck!
D4matic is offline   Reply With Quote
Old 01-10-2006, 05:57 AM   #4 (permalink)
For 2000 E320 4matic, the part #210-821-15-51.
Old 01-10-2006, 07:39 PM   #5 (permalink)
JG
This part number is a blower regulator which probably contains a resistor. Did you have a mechanical whistle noise like we do? From what I have read, this regulator is necessary to fix a blower that will not change speeds. My blower changes speeds just fine, I just get this ittermitent whistling or chirping, which sounds mechanical. Can the regulator, an electrical component, cause or make this noise?
Old 01-11-2006, 07:36 AM   #6 (permalink)
Change the regulator and the noise will go away. You are right that its sound like mechanical problem with the blow motor but it is not. I changed the motor twice and the noise would not go away until I change the regulator/switch. This is a common problem with regulator. Change it and the noise will go away.
Old 01-11-2006, 08:40 AM   #7 (permalink)
Vehicle: E320 2002
Thanks for you input, sounds like this is my problem too, do you have any instructions on how to change the regulator?
Old 01-11-2006, 11:49 AM   #8 (permalink)
Remove the panel under the glove compartment, its easy just few screws. You will see the blow motor under glove compartment. Remove few screws that holding the motor and you will see the switch that attached to the motor. If you are handy, you should not have any problems to replace the switch. It just like replacing your cabin filters. Good Luck!
Old 03-03-2007, 10:37 AM   #9 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
did anyone fix this noise with a new regulator?
I have the noice now, and its annoying as hell
OliverK is offline   Reply With Quote
Old 03-03-2007, 11:01 AM   #10 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Noise from the regulator is news to me, but then again, I learn a lot about these cars from fora such as this.
Is this a "feature" of the new-style regulator only? Has anyone ever seen this problem with the old-style?
A motor bearing can also make some squeaks, but this would sound like a motor squeaking. Mine made a very faint noise when going around a right turn. A few drops of oil fixed it.
