When I drive for about 30min, temp is set around 90c, once I stop and stay still for about 3-4 min, temp starts going all the way to 120, almost RED. The wierd thing is, it is ok if I drive less than 30min, than I can stay still for 15min, and temp is perfect 90c, but over 30 min driving, it overheats. I have to either turn heater on MAX to cool the engine down, or start driving again, as it starts cooling down.
Anyone, has any suggestions. Thermostat problem? Why not overheating sooner?
ok, I see two type of fans. There are 2 smaller once afront of the radiator and 1 big one that is connected to the engine and is behind radiator (looking at the front of the car). The big one is turning. So which one is electrical fan? Sorry, dumb question, but my name says it all. [:)]
The ones in front are the electric ones, My 01 did not have an engine driven fan as yours does. This is controlled by a thermal viscosity drive I believe. That too could be bad. None of this stuff is real expensive but it is very important with an engine that contains lots of aluminum. Get it fixed ASAP or sooner
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: overheating problem
See if the electric fans in front of the radiator are comming on or check to see if the belt that goes from the drive side fan to other one has not broken or become jammed. You need air flow over the radiator or the temp will climb up. You may need to change you coolant or have your radiator flushed is see if it is getting plugged up.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
Just to give update top those that may wonder. Took it to MB shop, they replaced thermostat since it was opening at 97c, and replaced the fan clutch, since it wasn't efficient and not enough airflow. New thermostat opens around 85-90c, and my temp is now just around 87c.
