| RE: Seeking ignition switched power in trunk or near battery My CD changer has a bracket holding the changer to the edge of the trunk lip. Pull those screws and gently lift -- don't kink or bend the fiber optic cable.
You should be able to test for a hot lead with everything off and a VOM with one side grounded.
There is also a large handful of unused leads for a factory COMAND system or cell phone behind the left sidewall card board panel -- the one next to the CD player (You still need to pull the CD player first to get room to move the panel without hurting anything)
Good luck.
Mike
Now: 2000 E320, Then: 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
