Old 12-18-2005, 09:42 PM   #1 (permalink)
crsh2's Avatar
Date registered: May 2004
Vehicle: 2000 CLK320
Where is the fuse located?
I know there is one in the right side engine bay, is there another one somewhere?
when i try to Signal,(Left or Right) light does not work but the hazzard does.
any ideas?
thanks
crsh2 is offline   Reply With Quote
Old 12-18-2005, 11:16 PM   #2 (permalink)
Date registered: Jul 2004
Vehicle: 1999 E320 Wagon demoted to parts car
RE: Where is the fuse located?
I believe the fuses for the lights in question are located on the side of the dashboard on the driver's side. Open the drivers door and you should see a triangular shaped cover. Fuses are located behing it. There is also another fuse block located with the battery.
E Wagon is offline   Reply With Quote
Old 12-19-2005, 09:40 AM   #3 (permalink)
crsh2's Avatar
E Wagon - 12/20/2005 10:16 PM
THANK YOU i will locate it tonight and post an outcome
goodday
Old 12-20-2005, 11:46 PM   #4 (permalink)
crsh2's Avatar
crsh2 - 12/21/2005 8:40 AM
goodday
thank you again i found the burned out fuse. its been replace and its working now
thanks
