Old 12-05-2005, 11:31 PM   #1 (permalink)
Date registered: Nov 2005
Send a message via Yahoo to hadam
Fuel Level Sending Unit
In my 1997 E-420 W210, I am having problem with fuel gauge.
Most of the time it show my tank is full. I know the problem with sending unit.
I got following part number from MB Stealer for Fuel Level Sending Unit 210 542 41 017. The part cost is $109.
Is any one know how to change the fuel level sending unit?? Any help in DIY process will be greatly appreciated.
hadam is offline   Reply With Quote
Old 12-06-2005, 06:13 AM   #2 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
RE: Fuel Level Sending Unit
Before pulling the sending unit check the resistance of the sending unit, I think if the connector is off it reads max. Fill the tank, check the rsistance drive a hundred miles or so and do it again. With a variable resistance box you could simulate it to check the guage. Otherwise plug in the new one to see (they might not take it back since it is electrical)
Peter Guenther is offline   Reply With Quote
Old 12-07-2005, 10:09 PM   #3 (permalink)
Do you know what resistance in Ohms I need to simulate the fuel level sending unit.
Should I start with 3.3K ohms and work down ward ?
Let me know.
Old 12-08-2005, 06:47 AM   #4 (permalink)
All I can find is that the resistance increases as the tank gets empty, that must mean 0 at full and probably a few hunderd ohms at empty. Start high, in my 140 manual you can not change it with a full tank, and it has a ring holding it in the tank that is loosened by a plate with two pins. there is a "o" ring below the sender. It shows removing the tiner the sender is in the top rearward side.
From my "boat" experience it is usually 0-300 ohnms for a sender but you never know with the Germans
Old 12-08-2005, 09:22 AM   #5 (permalink)
I just found another document that says the opposite, low resistance on empty, high on full!
