My MY 2000 E 320 will soon be hitting 60,000 miles mark. My service advisor has been telling me for some time that 60,000 service is fairly expensive (Approx. $ 800-900).
Has anybody on this forum gone through 60,000 service ?. If so, can you please advise on this. Should I go with the dealer or look for outside shop.
What is so special at this service (Spark Plugs + Oil/filter+Carbon filter+???????) to cause the bill to be $ 800-$900
The owner's manual lists what needs to be done at 60,000 miles. There is also a time limit on others things like brake fluid and coolant that might be coming due too.
My advisor has told me that the spark plugs on my 01 E430 cost 500-600 to change. He says that the 8 cyl engine has 16 plugs and that they are hard to get too so there is a lot of labor involved. Not sure if everything he said was true (my car just had the 50K service) but that is prob. where the cost if from. Not sure about the 6cyl but it sounds like the same thing.
If I were you I would pay to have the tranny fuild changed even if it is with your local mechanic. Just make sure it is OEM MB tranny fluid (nothing else)
MB will say the tranny fluid is lifetime (100K) but there is no such thing.
My tranny blew up at 70k and cost $5000 and the oil was chunky and black, not red like when it is new.
Do your self a favor and change the fluid.
Good luck
Mario
99 MB E55
HPS Gen I supercharger custom pulley
EvoSport lightened pullies
CoolingMist chemical cooler 50/50 Meth/H2O
H&R Sport Springs w/ #1 MB pads
Koni adjustables
K&N Filter
Removed Res and Magnaflow muffler
Lorinser roof wing
Upraded H.I.D. Crystal "face lift" head lamps
Brabus Shifter and flat hood emblem
All Black Emblems
19" staggered HRE 448R
2 12" Infinity Subs
I notice some people are changing their spark plugs at 60,000, my question is don't we all have the 100,000 mile spark plugs? Please correct me if I'm wrong.
5 year or 100,000 is what I understand. Just did a '98 E320 myself and the electrodes were well warn with 48k on the ticker. Car gets started and stoped alot.
I am close to you here in Louisville KY. I am a MB technician. I will do work at home for discounted rates.
There is no set 60k service on your car. it is a flex service car and all items are kind of alacart.
If no major service has been done, it will need.
engine air filter, fuel filter, spark plugs, brake flush, coolant flush, charcoal filters,
flex b(dus filter, wiper, oil and filter, tire rotation and check EVERYTHING on the car)
Please let me know if you are interested in having me do this.
Good luck
Mario
Is it a simply drain and change or do 'things need to be drilled open', etc.?
