Old 11-17-2005, 03:06 PM   #1 (permalink)
Date registered: Nov 2005
E320 windshield wiper
2001E320W large single blade windshield wiper smears!
I replace rubber insert with Mercedes insert every few months. Dealer has also tried bending wiper arm to apply more pressure to blade. I also tried aftermarket blade. No success. Problem seems to be not enough pressure applied uniformly over wiper length resulting in smearing in upper quadrant of sweep-right in line of sight. Dangerous driving in rainstorms. Suggestions appreciated.
cardoctor is offline   Reply With Quote
Old 11-17-2005, 03:42 PM   #2 (permalink)
Vehicle: ML500, E320 4Matic
RE: E320 windshield wiper
Never had this problem when I had my 01 E Class. Found the wiper excellent and in fact I liked it better than my 05 W211 wipers. Perhaps you need a new arm on it. There is not much else that can effect it
sosh is offline   Reply With Quote
Old 11-17-2005, 03:50 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, Cardoc, welcome to the forum.
There is also a very strong spring in there, it's possible that has weakened over time. It's also possible someone was being a jack**s and purposefully yanked on your wiper arm at some point.
It's got to be very expensive, but I think it would be worth replacing the arm and spring.
Good luck and enjoy the ride,
Greg
Old 11-17-2005, 06:06 PM   #4 (permalink)
Sandro N's Avatar
Date registered: Feb 2004
Vehicle: Hooked up 96 E320
Try removing the rubber blade and reinstalling it in the opposite direction.
I did this to mine because my wiper was skiping, now its not. Good Luck
sandro natale
Sandro N is offline   Reply With Quote
Old 11-18-2005, 09:13 AM   #5 (permalink)
Date registered: Jul 2004
Vehicle: 1999 E320 Wagon demoted to parts car
Also check the condition of your windshield. If it has many fine scratches in it from dry wiping then water will get in the scratches and distort your vision. You may be able to buff out the scratches with cerium oxide.
E Wagon is offline   Reply With Quote
Old 11-19-2005, 07:33 AM   #6 (permalink)
Insulator's Avatar
Date registered: Feb 2005
Vehicle: 99 E320 98 SL500
Typically I purchase all replacement parts from OEM sources. In this case though I found a manufacturer that makes a superior product.
The name of the company is SilBlade at the website of the same name. They manufacture a silicone-based blade that doesn't seem to overload the wiper transmission and keep my windshield streak free. I have had the same blade on the car for almost a year with no degradation of performance. They also offer a winter blade but I'm not sure I would use one because of the flimsy 210 wiper transmission
Best part about it they cost about the same as dealer parts.
Insulator is offline   Reply With Quote
Old 11-19-2005, 11:24 AM   #7 (permalink)
mrhappy71's Avatar
Vehicle: mercedes e320 2000
I have the same reoccuring problem every couple of months. I have tried everything. But the
dealer glady sells me the part for a mere $35 because they just dont sell the blade anymore i was told you need the whole piece. How nice of them.
mrhappy71 is offline   Reply With Quote
Old 11-19-2005, 01:50 PM   #8 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
I had streaking and chattering. While I waited for
my bosch blades to arrive, I couldn't stand it any
longer and applied liberal dose of silicone (out of
a spray can) to the blade. I let it absorb for about
5 minutes and applied again onto kleenex. Then I used
see-saw motion, letting this work into the blade. did
did for about 5 minutes. It came back to life and not
only did the streaking stop, the chattering ceased and
it has been an amazing performer for the past year....on
the old blade. I never had to swap out for the new one
yet.
Methinks the silicone had moisturizing qualities and
softened the hardening rubber, allowing it to become
soft....and more pliable again.
Even during cruddy mist (not rainy) conditions, I
figure it will emit a squeel, a grunt, or a chatter....
but noooo, it remains eerily silent.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 11-19-2005, 02:21 PM   #9 (permalink)
Mr. Pie's Avatar
Date registered: Nov 2004
Vehicle: CLK320 / E500
Send a message via MSN to Mr. Pie
I'll have to try that. [:)]
2001 W208 Black Opal Metallic
K2a, K3, K4 + COMAND, HID halo projector headlights, flat hood emblem, chrome cluster rings, Bluetooth phone adapter, MB illuminated door sills, AMG steering wheel, AMG pedals, chrome AMG II dual spoke wheels, Nitto NT 555 Extreme Performance, 235/35/19 front, 265/30/19 rear
2004 W211 Platinum Blue Metallic
Premium Package, Apperance Package, Keyless Go, Bluetooth puck and tail
Mr. Pie is offline   Reply With Quote
Old 11-21-2005, 12:40 PM   #10 (permalink)
Date registered: Jan 2005
About a month after buying a new blade, I was disappointed that the blade was streaking again during a heavy rain. I stopped at a gas station and used a paper towel to clean both the rubber blade and the windshield. Back to new.
albertm1 is offline   Reply With Quote
