Old 10-29-2005, 05:24 PM   #1 (permalink)
french mercedes's Avatar
Date registered: Oct 2003
Vehicle: 500 SEC AMG, 560 SEL, 500 SL R129, E 230 W210, 190 E W201, C43 ///AMG
how to change your break disk
i make a tuto (in french but the photo dont need the text for understand)on my web site
http://mercedes-benz.forumactif.com/viewtopic.forum?t=875
if it can help anyone here , i m happy !
http://www.mercedes-damien.com
my forum :
http://mercedes-benz.forumactif.com/index.forum
my 2 W126
french mercedes is offline   Reply With Quote
Old 10-29-2005, 11:27 PM   #2 (permalink)
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 00 E320
RE: how to change your break disk
A really nice post. It would be a really great post with a translation to the Queen's tongue.
I see what it takes to get the rotors off. You wail into the disks with a hammer that looks like a small block V8 on a stick.
I was (merely) whanging away with something that looked more like a 4-banger on a stick.
Mike
Now: 2000 E320, Then: 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline   Reply With Quote
Old 10-30-2005, 01:09 AM   #3 (permalink)
Mr. Pie's Avatar
Date registered: Nov 2004
Vehicle: CLK320 / E500
Send a message via MSN to Mr. Pie
Here is a loose translation: (hopefully FM would like to rework it or I can do it for him with my limited french schooling and with the help of Microsoft Word [:)]).
Greetings, today I changed the pads and rotors on my E230 (W210) also I have full with photographs for in to make profit all the world. This is valid also for other Mercedes with clamp of the same type!
Initially immobilize the car! then loosen the bolts on the wheels then put the car on jack stands, or better like me a bridge! completely bolts of wheels and deposit the nose gear wheels.
Start by removing the spring of the clamp floating with means of a screwdriver without forcing of too.
Then as you can notice it it is impossible to leave the brake pads without dismounting the clamp. Above all, push back the brake pad using a screwdriver by using the lever on plate to push back the piston of brake slightly. Then deposit them attaching bolts of the clamp with a key of 19 with tube or other if at you it is not of 19! If that forces a little it is normal: of origin there is Freinfilet on the bolt thread for empecher which they loosen in rolling, will thus be necessary to give some to rests!
below one should see these 2 bolts:
caution! once that you removed the 2 nuts you must support the clamp if not you are likely to botch the flexible device of brakes if the weight of the clamp put in tension the flexible device. To avoid having with to hold during lead you can hang it by means of a wire of metal coat rack to the spring of the suspension thus evitant to damage the flexible device and leaving you your finally free hand!
Like this:
Now that us quiet one summons can start with to unscrew the small screw which retain the disc with the hub of wheel by means of one Alen key by retaining the disc of the other hand (perso I have to use a key has tube like extension cable to gear down the exerted force). like this:
Then your disc "being stuck" by time for the hub it is necessary to pass by the method conan the barbarian! In all way it disc then died not of remors! one will type above with a large hammer! but before one takes care to give a bolt of wheel on that and of to screw up with the hand a little so that it takes on the hub, which will permettera to prevent that the disc flies when you type above (and to take it in full pear!). Like this:
After having removed the disc, pass a blow of brush metal on the hub to remove the oxidation, like that:
a then little oil on the hub, very little just for to avoid a future Re oxidation:
personally I just soaked my finger in oil and spread out that over the hub and its flask as on the image if above.
Then one turns over on our caliper whom one suspended has a wire, one starts by disconnecting his catch the sensor of wear like this:
now that the sensor of wear is disconnected one will be able to leave the old worn pads. and then to leave the remainder the sensor wear the old worn pads like so below:
as that you will be able to rest that on your new plates.
Then we will clean the parts or the pads must slide in order to facilitate their displacement and with this intention one will leave the cage the etrier who is just threaded on 2 let us tetons chrome which is screwed on the body clamp but one does not require to unscrew them considering that leaves without that!
on photograph I designe of the finger the hole or engages the famous ones tetons.
Then pass the parts or slide the pads has the metal brush like this:
Then one makes of same on the parts that there is on the clamp:
then one takes an old brake pad (do not do it directly on the piston if not you go the déteriorer)and by means of a greenhouse joint one return the piston in the etrier like this:
Attention on the level of brake fluid in the bottle, with the need to withdraw some with means of a syringe or a pear bus when one compresses a piston the level go up in the bottle!
If as me you make your levels regularly, I have to withdraw a little liquid if not overflow guaranteed and do not forget the brake fluid botch painting!
Then one the cage of clamp gives to its place:
Then I council to put a small sandpaper blow on the field of the plate to have a less direct attack and to avoid the squealings:
One replaces then the capteurd' wear on the new plates like this:
This being made we will clean the threading of the 2 attaching bolts of the clamp using a metal brush (me I was not caught the tete I have used a rotary metal brush)
Remain more than has to pose the discs nine without forgetting to screw up the small screw with the Alen key:
One sets up the plates in the clamp (attention the springs on dimensioned of one of the plates must return correctly in the hollow medium of piston of the clamp) then one puts freinfilet on the bolts of étrié that one cleaned précédement (attention a drop is enough if not later impossible of desserer!) :
After that one ressere these bolts with the couple using a torque wrench (couple of 115) and one replugs in his catch the sensor of wear of the plates of brakes. one can see the wire which remained on the spring of suspension that one will not have to forget to remove!
To finish we position back the spring (it is not easy but with patience...one arrives there!) and work it veiled is nikel!
Then you do the other with dimensions and finally you go up your wheels, rest convey on the ground will resserez your bolts of wheels and finally attention very important : to pump on the footbrake pedal several times before moving the car if not your 1ere braking will be finished at the hospital because the pistons are not against the plates and celleci must be well in place! controlez your level of brake fluid and made the supplement with the need.
Then small precaution, your brakes are new also it will be necessary to grind your brakes then in one the 1st time avoid the brake applications violent or brakings forts. Then little by little roll as usual quietly during 200/300 km after your brakes will be ground and veiled finished!
Not being pros of mechanics I spent 2 hours to do all that (the 2 front discs!) by counting time to find the tools (it is longest !) and to take the installation for the photographs that my small wife travelled by bus Nico you believe when same step that I would touch my beautiful very new numerical apparatus with hands in this state?
2001 W208 Black Opal Metallic
K2a, K3, K4 + COMAND, HID halo projector headlights, flat hood emblem, chrome cluster rings, Bluetooth phone adapter, MB illuminated door sills, AMG steering wheel, AMG pedals, chrome AMG II dual spoke wheels, Nitto NT 555 Extreme Performance, 235/35/19 front, 265/30/19 rear
2004 W211 Platinum Blue Metallic
Premium Package, Apperance Package, Keyless Go, Bluetooth puck and tail
Mr. Pie is offline   Reply With Quote
Old 10-30-2005, 10:22 AM   #4 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
It is interesting to see that he did not use anti squeel paste. An online parts vendor also recommended me not to use any paste at all, with OE pads.
It's also worth noting that he screwed one wheel bolt on the disk "into the hub" before he hammers it off so that it won't fly. (It is in his text and on the picture: "but before one takes care to give a bolt of wheel on that and of to screw up with the hand a little so that it takes on the hub," or "use your finger to screw the bolt into the hub....")
Thanks to both the original french posting and the translation. I learned something today again.
cerritos is offline   Reply With Quote
Old 10-30-2005, 01:09 PM   #5 (permalink)
Vehicle: 00 E320
Mr Pie - I am not only grateful for the information provided by the translation, but for the incredible humor offered by the mechanized translation from French to something that almost resembles English.
Hilarious[:)]
Old 10-31-2005, 06:16 AM   #6 (permalink)
i m sorry for the french version but my english is awfull and i dont know how to translate exactly but if my photo help you i m happy !
Old 10-31-2005, 06:54 PM   #7 (permalink)
Vehicle: 2001 E320
french mercedes - 10/31/2005 8:16 AM
It's a very good and detailed job, very good pictures. I appreciate it. I also appreciate the effort that was put into the translation. That made the understanding possible. Thanks to both french mercedes and Mr. Pie again.
Old 10-31-2005, 07:55 PM   #8 (permalink)
Vehicle: 2001 E320
french mercedes,
Some members here said that it's very difficult to remove the rotor disc. One even removed the disc together with the hub.
You used a big hammer to bang on the rotor disc to remove it. How much force did you use? light tap? or really hard force? How many times did you bang on it? Do you think there maybe a risk of damaging the hub? Where is it stuck? on the back of the disc? or the center hole?
Old 10-31-2005, 09:02 PM   #9 (permalink)
Mr. Pie's Avatar
mjhawkins2346 - 10/30/2005 12:09 PM
Hilarious[:)]
That is so true... I only have four years of high school french behind me and I haven't used any of that knowledge for 15 years now. I just love how MS Word can translate from one language to another, but it makes the translation more of a joke then anything else. [:)]
Old 11-01-2005, 05:06 AM   #10 (permalink)
cerritos - 11/1/2005 3:55 AM
french mercedes,
i use a big force on it and i bang it only one time ! It s a principal reason to put a rim's bolt ("boulon" in french)before to bang on tne old disk , if you dont used a wheel bolt the disk risk to flying in your mouth ! it's dangerous !
the disk was simply stick by the oxidation.
