Old 11-01-2005, 04:04 PM   #11 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
RE: how to change your break disk
french mercedes - 11/1/2005 7:06 AM
i use a big force on it and i bang it only one time !
Thanks for your explanation. From your pictures, it seems that it's mainly stuck in the center of the disc instead of the back of the disc. I guess you did not have any concerns of damaging the hubs either. Thanks again.
p.s. I like your humor. "Conan the barbarian, disc flying into your mouth...."
cerritos is offline   Reply With Quote
Old 11-01-2005, 04:46 PM   #12 (permalink)
french mercedes's Avatar
Date registered: Oct 2003
Vehicle: 500 SEC AMG, 560 SEL, 500 SL R129, E 230 W210, 190 E W201, C43 ///AMG
well, my friend (it's a chief of mécanical staff in MB center) say that they used this simple methode for remove the old disk ! one chock was not dangerous for the car , your only one risk is you can break the old disk but is not too important because it was dead !
i like the humor, if we dont used the humor the life was very grey isn't it ? [;)]
http://www.mercedes-damien.com
my forum :
http://mercedes-benz.forumactif.com/index.forum
my 2 W126
french mercedes is offline   Reply With Quote
Old 11-02-2005, 01:49 AM   #13 (permalink)
Vehicle: 2001 E320
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1231784&posts=8&fid=17
From this posting, you can see that there are discussions about the difficulties of removing the disc.
It seems that it's not that difficult for you by using your approach and the big hammer of yours. One day, I'll have to do it. I'll say about 20K more miles on the dial. I'm prepared.
Old 11-02-2005, 01:09 PM   #14 (permalink)
i think that your Mb dealer used the same practise ! but you save many dollars if you made it yourself ! [;)]
Old 10-04-2008, 11:52 PM   #15 (permalink)
Vehicle: 2001 E320
Translated by Google.
Translated version of http://mercedes-benz.forumactif.com/w210-et-w208-f15/tuto-changer-les-disques-plaquettes-de-freins-sur-w210-t875.htm
Old 10-05-2008, 12:04 AM   #16 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
JMHO, but the safest way to remove a brake disk is the way I described in the DIY post.
If you must use a hammer, two points of note: DO NOT REUSE THE ROTOR. Once you have hit it with a hammer (even if you don't get it off) it is now a doorstop. Second, wear good face protection (not just eye protection, but a whole face shield). Rotors can break and the pieces can come off of there with enough velocity to penetrate skin.
Lastly -- and I can't implore you strongly enough on this point -- if you don't know what you're doing, face shield or no, just don't do it. Whacking blindly away with a hammer, you may end up damaging other things; paying someone else to get the stuck ones off is usually cheaper than paying for the other things that get broken in the process.
Take care and enjoy the ride,
Greg
Meister Eckhart
