Old 10-26-2005, 01:58 PM   #1 (permalink)
Godiva's Avatar
Date registered: Jul 2004
Vehicle: 2005 E320 4matic S/W
Send a message via AIM to Godiva
Rattling noise under car - cats replaced - check engine light
Just a follow up to thank all of you: originally thought the noise coming from under my '02 E320 4matic wagon (61,000 miles, I am in the USA) was a loose exhuast pipe but my husband put it on the lift & found nothing.
When my "check engine light came on while excelerating, I checked the forum for info & had my husband take another look: sure enough, it was the catalytic converters on both sides. Took the car into the stealership & they did the work - no charge - since it was under 7yrs/80,000mi.
HOWEVER, they said the "check engine" light was due to codes PO300, PO301, PO302, and said the plug wires were bad and wanted $500 to replace. They also wanted $600 to tighten/replace "loose ball joints".
We said NO THANKS & picked the car up today, but the check engine light is now off, yet the engine still bogs upon aceleration. What gives? (BTW, we replaced the MAF & air filter a month ago.)
Should I replace the wires & plugs?
Godiva is offline   Reply With Quote
Old 10-26-2005, 04:55 PM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: Rattling noise under car - cats replaced - check engine light
Have you changed the fuel filter? Also you may want to change the spark plugs with 60K miles on it. They say that they are good for 100K but it might be worth it to change them.
I had to have my cats replaced at 30K miles for rattling. The federal law is 8 years or 80K miles for replacement.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 10-27-2005, 09:25 PM   #3 (permalink)
Date registered: Dec 2004
Just had my ball joints replaced for $300. Your $tealership wants way too much for the plug wires. The plug wires on your car are extremely short, and there's no reason why they should be bad. The tune-up interval is 100k miles. If you're mechanically inclined, you can replace the plugs and wires yourself for cheap.
lexrex is offline   Reply With Quote
Old 10-29-2005, 07:21 AM   #4 (permalink)
Godiva's Avatar
Great advice, thanks, E-Klasse!
Ordered Bosch plugs, plug wires (one wire was bad, so my husband is replacing them all) and a fuel filter online from http://www.thepartsbin.com/ ..ordered them Thursday afternoon and they were here the next day! Gotta love the internet. Total cost - free shipping over $50 - was $303.
I also got a CEL (trouble code) reader off of Ebay for $60, which included a code manual. It will also clear the check engine light after displaying the code 5 times.
Old 11-27-2006, 01:52 PM   #5 (permalink)
sdanville's Avatar
Date registered: Nov 2006
Vehicle: 1999 ML320
so what happened ?
i have the same problem.
at 120,000 miles. mutliple cyl mis fire.
autozone guy says plugs or wires. but all at once ?
I had PO301 to PO306
at 100,000 i replaced the fuel pump ,filter, plugs, CPS and today the MAS.
steve
sdanville is offline   Reply With Quote
Old 12-20-2006, 06:45 PM   #6 (permalink)
Date registered: Dec 2006
I had engine check light on my 1999 E300 Diesel. I changed main air master sensor $280.00 CDN +tax and the problem is gone.
vlas is offline   Reply With Quote
