On my 2000 e430 sport, I am getting a metallic clunk when I put the car in gear, it is definitely coming from the drivers side rear wheel, suspension, brake assembly?? Anyone help????
Possibilities are flex disc at the end of the drive shaft, or if you're pretty certain it's coming from a wheel, it could well be a caliper bolt that's loose or broken.
If it's the latter, your ability to stop safely could be impaired - - -suggest you pull the wheel and check it out or take it in for service as promptly as possible.
