Old 09-25-2008, 02:07 AM   #111 (permalink)
Date registered: Aug 2006
Vehicle: 1999 E300DT
Originally Posted by 247hoopsfan View Post
I did this repair on my right rear today. Everything went smooth, but the black plastic retaining clip under the window rail is broken. Do the dealers carry this obscure part?
According to the EPC, it is P/N 201 735 00 85
Item # 14 in the diagram:
Каталог
1982 320i
1999 E300DT
2005 Pathfinder LE
Dave1965 is offline   Reply With Quote
Old 10-03-2008, 08:43 PM   #112 (permalink)
BuffaloBenz's Avatar
Date registered: May 2008
Vehicle: 1998 E320 4Matic Silver, 1998 Volvo V70 Green
Thumbs up Ashman78 my hero tonight
Thank you Ashman78. Just completed replacing my left rear door window regulator.
Dealer quoted $404.00 plus $36.00 sales tax= $ 440.00
I purchased part from stopshopanddrive.com for $49.00 including UPS.
Took me one hour and twenty minutes from start to finish. Excellent instructions and photos saved me $ 391.00
I say... if you ever make it to Buffalo I owe you a beer or two. Thanks again
BuffaloBenz is offline   Reply With Quote
Old 10-07-2008, 04:50 PM   #113 (permalink)
Date registered: Feb 2008
If I attempt to replace my front driver side window regulator per these instructions, will I run into any problems with the SRS airbag in door? (other than disconnecting whatever wires may be connected to it)
martinleibrock is offline   Reply With Quote
Old 11-09-2008, 06:04 PM   #114 (permalink)
Date registered: Jun 2008
Great job - thanks Ashman & Yachtmaster for excellent DIY instructions.
On models with an Air bag, there is an additional door panel screw under the "SRS" emblem.. Just gently pry it off with a screwdriver and then remove.
bdear115@aol.com is offline   Reply With Quote
Old 11-15-2008, 07:33 AM   #115 (permalink)
lyntis's Avatar
Vehicle: 1996 E320
Send a message via AIM to lyntis Send a message via MSN to lyntis Send a message via Yahoo to lyntis
are there any instructions for the front door window regulator?
lyntis is offline   Reply With Quote
Old 11-21-2008, 10:59 PM   #116 (permalink)
Date registered: Nov 2006
I just replaced my left rear window regulator. Thanks to all who posted information on how to do this job. I paid $46 plus shipping from Stop shop and Drive. It is a Febi/Bilstein. Has anybody else used this brand and what has been your experience how well it will hold up. Some of the holes didn't quite match up and I had to bore them out just a little to get the bolt in. I used 5MM bolts instead of rivets. Thanks in advance for any replys.
Meyer is offline   Reply With Quote
