Old 08-30-2008, 03:46 PM   #101 (permalink)
Vehicle: 2001 E320 2WD
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
I have 2 rear door regulators with plastic slider(Bushing) broken that I want to repair using after market part. I have the parts now with me. If you know how, please let me know. I am just trying repair them and keep them as spare.
I just did regulator replacement with after market parts. It is working fine. Maybe better than original part.
Raylee177 is offline   Reply With Quote
Old 08-31-2008, 01:03 PM   #102 (permalink)
Date registered: Sep 2007
Vehicle: 2001 E430 4Matic
window regulator.....SRS question
This thread has been very helpful, I have ordered a window regulator part to fix my passenger rear window. I have a quick question....my car has a side air bag and previous posts mentioned that it should not be an issue when replacing the part...however I am thinking it might be wise to disconnect the battery before starting.....any thoughts? Thanks
redwing201us is offline   Reply With Quote
Old 08-31-2008, 01:13 PM   #103 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
It is almost never unwise to disconnect the battery if you're going to be working around the wiring, even if you're just disconnecting the window motor wiring (which you might want to do).
While you are very unlikely to damage or deploy the airbag, it is still a good idea to disconnect the battery. Be sure to locate your radio code card first.
Old 08-31-2008, 01:29 PM   #104 (permalink)
Thanks Matt. I will disconnect the battery(luckily I found my radio codes).
Old 08-31-2008, 08:46 PM   #105 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hi, Raylee. It's in the other sticky for this item:
http://www.benzworld.org/forums/w210...-question.html
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 09-20-2008, 03:16 PM   #106 (permalink)
window regulator chicago
i was going to attempt a diy on the window regulator, even bought the part off of ebay. However, the guys at advance auto store gave me a name of a company in joliet, il that will install the regulator for $45. So I went and they did a good job in 45 minutes.
cost of regulator $37 (including shipping) ebay
install $45
$82 total...not bad considering my indie mechanic wanted $290 and the dealership $390!!!!!!
Old 09-20-2008, 05:22 PM   #107 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
install $45
So you spend several hours shopping around and waiting for the job to be done on the top of $82.
I do the job in 1/2 hr on my driveway with $7 material cost and about 3 extra minutes to place Internet order.
Kajtek1 is online now   Reply With Quote
Old 09-20-2008, 05:57 PM   #108 (permalink)
Good for you....i'm still new at this and it probably would have taken 2-3 hours...so it was worth it....thanks for your comment.
Old 09-20-2008, 06:10 PM   #109 (permalink)
mpr2007's Avatar
Date registered: Jul 2007
Vehicle: 2001 E320 4MATIC, 210.082, 112.941, WDBJF82J61X051xxx
Just did my passenger rear today. Took 20 minutes! One hint if using the correct steel rivets (0039902497) - get a heavy duty rivet gun. I had a fairly long handled rivet gun and although my hands are pretty strong, I ended up having to augment the handles by adding a couple of two foot tubes over the end of the rivet gun to give me enough torque. Windows works like new!
mpr2007 is offline   Reply With Quote
Old 09-24-2008, 07:55 PM   #110 (permalink)
247hoopsfan's Avatar
Date registered: Jan 2005
Vehicle: 98 E320 88 300E
I did this repair on my right rear today. Everything went smooth, but the black plastic retaining clip under the window rail is broken. Do the dealers carry this obscure part?
1984 300D 225,000 miles (hit and totaled by bad driver)
1987 300E 209,000 miles (donated to worthy cause, still going)
1988 300E 205,000 miles (still a daily driver)
1998 E320 70,000 miles (Obsidian, 17' E500 rims)
1990 300CE 88,000 miles (Silver/ black int)
247hoopsfan is offline   Reply With Quote
