Anyone out there please explain the difference between the A& B Service and also the required milage for them?
Also how do you reset the on board computer once these servicing has been done?
Flexible Service System A-Service
Includes engine oil and filter change. Inspection of tires and tire pressure and safety brake inspection. Check and correct all fluid levels. Reset FSS indicator.
Flexible Service System B-Service
Includes all services in the FSS A-Service plus replace windshield washer inserts, remove and inspect wheels and brake system, lubricate and inspect throttle linkage. Check and correct all fluid levels and reset FSS indicator.
As for the required mileage you have to check your owner's maintenance manual for that. To reset the FSS indicator is in your owner's manual.
