Old 09-07-2005, 05:56 PM   #1 (permalink)
Vehicle: 2001 E320 2WD
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
20001 E320 CD changer problem
My CD changer stop playing. When I push CD, it says empty magazine. CD was playing fine before it went into radio mode automatically.
I think CD is bad but I could use some help from you with guidance.
Thanks in advance.
Raylee177 is offline   Reply With Quote
Old 09-07-2005, 06:38 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
RE: 20001 E320 CD changer problem
Hi, Raylee.
Mine did this a while back, on a dare I did the battery disconnect/reset and when I brought the radio back on line with the code, the trunk-mounted CD changer worked again. Seems kind of hokey, but it's certainly worth the attempt. Of course you also get to reset all of your windows and ABS/ESP displays, so it keeps you in practice. :)
Good luck and enjoy the ride,
Greg
Old 09-07-2005, 07:05 PM   #3 (permalink)
Thank you very much. I will try that.
Old 09-07-2005, 07:47 PM   #4 (permalink)
Date registered: Sep 2003
Vehicle: SL500, ML320, E320
I had a similar experience with our 99 SL and knew that the cassette was fully loaded with CDs..... I popped it out, made sure I had them all in correctly (I did) and put it back in.
It's been fine ever since . . I assumed that potentially some dust on the lens/reader or just the dreaded unexplained MB glitch.
regards-
CQRT
Scottsdale
CQRT is offline   Reply With Quote
Old 09-15-2005, 04:15 PM   #5 (permalink)
I ended up replacing CD changer for $250 plus core with 1 year warranty. This one had manufacturing code of year 2002 made in Europe, not in China.
