Old 09-07-2005, 09:57 AM   #1 (permalink)
Date registered: Jun 2005
Vehicle: 1998 E320
What is this and should it be ticking?
Drivers side near the window washer fluid reservoir.
THX
BOb
bob98e320 is offline   Reply With Quote
Old 09-07-2005, 10:56 AM   #2 (permalink)
SaMaS's Avatar
Vehicle: E55 ///AMG
Send a message via MSN to SaMaS
RE: What is this and should it be ticking?
Hi, I have same ticking really interesting to know if it should make that noise ... Thanks
SaMaS is offline   Reply With Quote
Old 09-08-2005, 09:14 PM   #3 (permalink)
Date registered: Sep 2003
Vehicle: SL500, ML320, E320
Cruise control component ?
CQRT
Scottsdale
CQRT is offline   Reply With Quote
Old 09-08-2005, 10:15 PM   #4 (permalink)
samhmbz's Avatar
Date registered: Oct 2004
Vehicle: W211.056C209W202W124
That is a purge valve and yes it ticks or pulses not all the time only when needed and during a obd 2 self test.It is used to vent the excess vapors ect. in the fuel system.
Sam
samhmbz is offline   Reply With Quote
Old 09-09-2005, 04:46 AM   #5 (permalink)
Vehicle: 1998 E320
THX
Old 12-20-2005, 01:25 PM   #6 (permalink)
Vehicle: 1998 E320
Sam,
I had it replaced today. Would the purge valve going south have any effect at all on performance?
Thx,
Bob
Old 12-20-2005, 01:44 PM   #7 (permalink)
Vehicle: 1998 E320
Think I found my own answer...
A purge valve is used to control the vapor flow into the engine. The purge valve is operated by engine vacuum. One common problem with this system is that the purge valve goes bad and engine vacuum draws fuel directly into the intake system. This enriches the fuel mixture and will foul the spark plugs. Most charcoal canisters have a filter that should be replaced periodically. This system should be checked when fuel mileage drops.
