Old 08-31-2005, 06:41 PM   #1 (permalink)
Date registered: Jun 2004
BAS-SRS-ABS Alert
Anyone have an idea what could cause the BAS-SRS-ABS warnings to appear after driving a few miles? They go away after shuting the car off but reappear after driving again. I had the same 3 faults appear when the battery went dead, so I ended up having to have a shop reset the computer.
dnewman is offline   Reply With Quote
Old 09-01-2005, 06:42 AM   #2 (permalink)
Date registered: Nov 2003
RE: BAS-SRS-ABS Alert
It could be a faulty brake light switch, a common problem and simple repair. It happened to my E430.
E430_4Matic is offline   Reply With Quote
Old 09-01-2005, 07:24 AM   #3 (permalink)
I checked the rear brake lights and they are stuck on. I am gong to replaces the brake switch today and see if it is the problem. I'll report back. Thanks
Old 09-01-2005, 05:13 PM   #4 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
I think you should read the thread regarding to resync after battery is dead/disconnected/replaced.
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1198710&posts=6&fid=17
quote from that thread:
"Synchronizing ESP:
If the power supply was interrupted (battery
disconnected or empty), the BAS/ESP malfunction
indicator lamp may be illuminated with the engine
running. Turn steering wheel completely to the left and then to the right. The BAS/ESP malfunction indicator lamp should go out."
cerritos is offline   Reply With Quote
Old 09-01-2005, 07:47 PM   #5 (permalink)
RE: BAS-SRS-ABS Alert (Problem Solved)
I replaced the brake light switch and the problem is solved. Thanks for the input!!
Old 09-02-2005, 11:57 PM   #6 (permalink)
Vehicle: 2001 E320
I also had BAS-SRS-ABS alert before. I took it to the dealer and it was under warranty repair.
Just in case that it came back again, did you replace the brake light switch by yourself or by a dealer?
Where is it?
Old 09-03-2005, 08:22 AM   #7 (permalink)
RE: BAS-SRS-ABS Alert Problem Solved
I fixed it myself. It is located next to the brake pedal. You have to remove the cover under the drivers side. There are 4 screws. Remove the screws and pull the panel loose. It just snaps into place.
Old 09-06-2005, 08:35 AM   #8 (permalink)
Date registered: Sep 2005
I followed your instructions, and I was also able to fix the problem. Thanks
emiche is offline   Reply With Quote
