Old 07-08-2005, 12:16 AM   #1 (permalink)
Babushka's Avatar
Date registered: Oct 2004
Vehicle: 2005 AMG E55, 1998 740i, 2005 1000RR, 1993 300CE CV Wide Body Twin Turbo
Need a wiring diagram for signal lights.
Please help if you can.
I'm replacing mirror covers with the turning signal ones and can't seem to locate the correct wire to tap into. I know there were several posts on this but the Search is not working for some reason.
I have (i think) tested all the wires running allong the right side doors, no luck.
If you know, please tell me where the wires are running and what color wires are for the left and right turning signals.
E-Klasse - please forward the instructions if you still have them. You have been and are one of the best resources on this forum.
Thanks.
Babushka is offline   Reply With Quote
Old 07-08-2005, 12:57 AM   #2 (permalink)
Babushka's Avatar
RE: Need a wiring diagram for signal lights.
Found a diagram but still can't test the wire positive.
http://www.autolib.diakom.ru:8001/CAR/Mercedes-Benz/1997/E320/SYSTEM%20WIRING%20DIAGRAMS/6231.pdf
Old 07-08-2005, 08:46 AM   #3 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
Pardon..am not E-Klasse, nor portray him on the tele
but I did save several tips on the installation of the
illum sills as I was planning to do this mod soon.
Try these - hope it gives the info you're seeking...
http://waltermitty.net/mb/illum%20sills%201.pdf
http://waltermitty.net/mb/illum%20sills%202.pdf
http://waltermitty.net/mb/illum%20sills%203.pdf
http://waltermitty.net/mb/illum%20sills%204.pdf
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 07-08-2005, 09:27 PM   #4 (permalink)
Babushka's Avatar
raymond- I did not mean to offend anyone...What I said was that E-Klasse is ONE of the great resources, there are many great resources on this forum.
Thank you very much for the info. I have located some of the original posts from E-Klasse and other members about this issue.
It seems that I was on the right track. But still unsucessfull. I traced the rear tail blinker wire which is black with green stripe (as shown on the diagrams and discussed in the posts), however I can not locate it in the right side under the door sills. Besides, I have tested every wire in the bunch and no go. So now I'm wondering (before stripping the whole car) is it possible that the wire in question is routed else where in my car. Or may be someone replaced the section of the wiring and it's there but different color (which is unlikely because I did test all of them).
Very stuck, any ideas anyone???
Old 07-09-2005, 07:57 AM   #5 (permalink)
raymond-'s Avatar
I was so hurt that I really didn't want to help you
anymore. :-) Actually, I was in a rush and didn't
realize that I posted links to the illuminated door
sills instead of your requested lighted/mirrors. So
let me dig for them. Just saw them several weeks ago.
...found them...
http://waltermitty.net/mb/blinking%20mirrors.pdf
Old 07-10-2005, 02:43 AM   #6 (permalink)
Date registered: Jul 2005
Send a message via MSN to interiormagic
i will try to stop by and help you out today, i'll call you. i still need those parts you were selling, email me at kendog943@aol or verizon
interiormagic is offline   Reply With Quote
Old 07-10-2005, 07:59 AM   #7 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
Go in to the trunk and look at the connector on each tail light. The wires are some what color coded in that they have a stripe of color on the black wire.
Remove the door sills on each side and locate the same size and color of the wire.
The best thing is to test to make sure you have the correct wire before you tap in to it. Take a pin and poke it through the insolation so that it contacts the wire. Take a test light (Any 12V automotive bulb) and connect one lead to the pin and the other to the body of the can for a ground connection. Now turn on signal flasher.
The wires for the turn signals are not very big in diameter. There may be other wires with the same color srtipe on them but they will not be the same size wire. Looking at the wires in the socket at the tail light will help identify it in the door sill without the use of a wiring diagram.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
