Old 07-05-2005, 12:40 PM   #1 (permalink)
Date registered: Jul 2005
E320 Head Gasket
Hi. Does anyone have any thoughts on a 95 E320 cabrio with 20,000 miles with a major leak. The dealer is claiming it needs a new head gasket.
MsKML is offline   Reply With Quote
Old 07-05-2005, 12:53 PM   #2 (permalink)
Vehicle: 2001 E320 2WD
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
RE: E320 Head Gasket
When there is a head gasket leak, you would normally see:
1. Radiator coolant going down although you see no coolant leak. Look at radiator expansion tank to determine that you are losing coolant.
2. If you open engine oil cap and look inside of the cap, you will see milky color. If you don't see it and color is normal black color, most likely head gasket is OK.
Try to get leak test done to make sure.
It is an expensive repair so make sure that you really do need head gasket. It could cost you around $2000 if not more depending on where you are getting it repaired. Never trust dealer 100%.
Good luck.
Raylee177 is offline   Reply With Quote
Old 07-05-2005, 12:53 PM   #3 (permalink)
Good luck.
Old 07-05-2005, 12:58 PM   #4 (permalink)
Thank you so much. I'll check it tonight.
Old 07-15-2005, 08:00 PM   #5 (permalink)
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 00 E320
A head gasket leak can also be weeping oil from the edge of the head to block joint.
This project was been suggested to me by the dealer, but a mechanic I trust said to keep an eye on it, but don't bother to rip everything apart unless I need to do other work, or it starts leaking badly.
You can guess whose advise I took.[:)]
Mike
Now: 2000 E320, Then: 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline   Reply With Quote
