hey guys.. new member here.... i'm thinking about getting the brabus replicas for my 01 e320. i;d like to get the 19's, but for comfort will go with 18's. i also am planning to get the eibach sport springs with koni shocks... anyone have this setup, how does it ride? btw, where do you get the brabus mb vi replicas?
you will have no problem finding the monoblock 6 replicas on ebay. or you can find a site that sells Moven wheels they make replicas for almost all expensive wheels.some look almost identical
I got a set of brabus mb6 18" on eibach's with Bilstein shocks. The ride is pretty good. 18" is not only an easier ride, those tires will save you a lot of money over 19" in the long run.
My setup is 18 inch carlssons with Eibach springs (standard shocks for now) and the ride is still as smooth as ever, though i could use upgraded shocks & an antirollbar sometimes.
IMO
If you are lowering and changing to more agressive shocks, what comfort will 18"s give you in place of 19"s.
I had 19" Monoblock V replicas, Bilstien Sport shocks, H&R sports springs, Pad #1, and 1/4 of a coil cut on the front. It handled better than my BMW 740i. The comfort is a very argumentative subject. I was very happy with the little stiffer setup, to me it was more comfortable.
It's a good thing you are going for Monoblock VI, because the replicas are made staggered 8.5 front and 9.5 rear. Monoblock V replicas were only made 8.5 all around so I had to spend more to get a spacer for the rear.
Although I would recommend 18"s if you race, 19" look a lot better and ride is not THAT much different. When you go to 20"s then you will feel it plenty.
