Old 06-30-2005, 12:49 AM   #1 (permalink)
Date registered: Jun 2005
Rear view mirror
Can anybody tell how to remove rear view mirror?
Model E230,'96.
andrievss is offline   Reply With Quote
Old 06-30-2005, 06:20 PM   #2 (permalink)
Sandro N's Avatar
Date registered: Feb 2004
Vehicle: Hooked up 96 E320
RE: Rear view mirror
First remove the light and sunroof switch assembly. then you'll see how to get it off. good luck
sandro natale
Sandro N is offline   Reply With Quote
Old 07-03-2005, 07:33 PM   #3 (permalink)
Date registered: Dec 2003
Hold each end of the mirror firmly and pull straight down hard. The mirror shaft is held in the base by springs and it takes a pretty good pull to remove it. There may be some wires in the shaft going to the base so be careful about making a wild snatch.
rander is offline   Reply With Quote
