The cupholder seems to lock into the compartment slots, however the console lid will not close when the cupholder is down, and when up the plastic "peak" at the rear of the left holder hits the front of the center arm rest cover. The cupholder came in a MB box, with part #B66920102, and the supplied instructions indicate it will fit a W210 (as well as the C-class).
Does anyone know if this is in fact the wrong part for my car and/or what the correct number would be?
I have/HAD the same cupholders in my W210. I decided to take it off as a precaution bec. i want to save myself from the dreaded $900-1100 Transmission Sensor Repair when you accidentally spill liquids in the center shifter console thus shorting the Sensor(Another common problem in all later MBs)...I would just recommend a door panel mounted cup holder...If you do decide to get the center console cupholder: BE CAREFULL NOT NOT SPILL LIQUIDS IN THE CONSOLE (transmission sensor part cost=$850 + $tealer Labor cost)
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse, thanks for the site. Lots of useful info there. I can't imagine I'm installing it wrong, though. It looks as though the three locating tabs on the bottom are lining up with the holes in the console, and the cupholder seems like it's locked in and down as far as it will go.
SaMaS, I'm afraid you're right. This must be the wrong cupholder.
If anyone has had success finding the right one for an '02, and has part number and/or site info, I'd be grateful if you could share. It seems like there's some misinformation about which cupholders will fit.
Hi, if it will help you I have some pictures, fist one is good cup holder from the front, second picture is bad cup holder from the same position look at these red markings , that is the differents, thats way it does not fit our 210, i think 208 have more space... sorry can't find part number i bought good one from e-bay just ask for the real picture before buying ... good luck , hope it's gonna help you
