Old 06-05-2005, 07:06 AM   #1 (permalink)
Date registered: Dec 2004
Black steel cover of the iginition switch
I have looked around and have not seen this for the 210. How do I get this cover off? It says to pry it off but no luck. In earlier models it references a small pin hole that you can stick a strong paper clip in to release the cover after you have the ignition in position #1. On the 210 I see no pin hole. There has to be a trick.
I have the intire ignition out of the car and just can't get the damb cover off the lock within the switch.
Bob
bob richards is offline   Reply With Quote
Old 06-05-2005, 08:48 AM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: Black steel cover of the iginition switch
http://www.edsoto.com/w210/disassemb...nter_step7.htm
Check out this video. You need a special tool to remove the ignition switch.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 06-05-2005, 09:00 AM   #3 (permalink)
If I just buy a new sleave do I still need the tool?
Old 06-05-2005, 09:31 AM   #4 (permalink)
The ring came off very easily with a small thin blade flat head screw driver rotating around the lock. The videos really helped though.
