Old 06-03-2005, 11:16 PM   #1 (permalink)
Date registered: Jun 2005
Spare Key Doesnt Start Motor But Opend Car??
Hi all
I have a 96 E200 that originated in Singapore but is now in New Zealand.
I have 2 keys. One works fine. The spare key however (with new batteries), opens the car through the remote fine, it turns the motor over, but the light on the rear vision mirror flashes red and green alternatively and the motor doesnt start.
Ive read a number of threads on this type of problem but cant work it out.
Any suggestions appreciated.
jroesten is offline   Reply With Quote
Old 06-04-2005, 02:16 PM   #2 (permalink)
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 00 E320
RE: Spare Key Doesnt Start Motor But Opend Car??
The key is really 2 pieces. A radio transmitter for locking/unlocking - and this is the battery you replaced, and an infrared unit for the ignition.
It sounds like the infrared portion of your key has lost it's programming.
I recall a post suggesting it can self-repair itself if you place the key in the ignition and not turn anything for several hours. Then remove and try again.
Someone else may have a better idea, but failing this you might plan a trip to the mechanic or dealer.
Good luck.
Mike
Now: 2000 E320, Then: 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline   Reply With Quote
Old 06-05-2005, 08:59 AM   #3 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
Look in the owners manual under the topic of re-synchronizing the remote once the battery is changed.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 06-09-2005, 04:42 PM   #4 (permalink)
Thx for the replies...I dont have an owners manual unfortunately..what does it say?
Cheers.
John
Old 06-09-2005, 07:51 PM   #5 (permalink)
Vehicle: 00 E320
I don't know if the '96 manual says more than the 2000 manual. It simply says "Put the key in the ignition to re-synchronize".
Isn't that helpful?[:(!]
I would try putting the key in the ignition and leaving it there for perhaps 2 hours. Then remove it, put it back in, and see if it starts the car properly.
Good luck.
Old 06-09-2005, 10:33 PM   #6 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Date registered: Jul 2004
Vehicle: SL, CLK & 5E's
I have the same problem with my E280, I've tried EVERYTHING! Does your car recognise the key? (does it click into the steering column like the other key?) if it doesn't then you'll have to get a new key (which costs a fortune).
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/41571.gif"border=0>
<img src="http://www.danasoft.com/vipersig.jpg">
Storm. is offline   Reply With Quote
Old 06-12-2005, 12:32 AM   #7 (permalink)
Hi ...tried the leave it in the ignition trick ...but no luck. The key opens and turns over the car but wont start...it is only a spare u never know when u might need it.
Thx again
John
Old 06-12-2005, 06:47 PM   #8 (permalink)
Vehicle: 00 E320
I know it sounds wierd, but try the "leave it in the ignition" trick a second time.
I have heard of the key doing more of what it is intended to do, feature by feature after repeated cycles.
Good luck.
Old 06-17-2005, 03:24 PM   #9 (permalink)
Thx for the interest Mike..appreciate it.
Ill let u know if I suss it out or if a bolt of lightning strikes either the car ..or myself :-).
Cheers
John
