Old 09-10-2008, 05:41 PM   #31 (permalink)
klwhitacre's Avatar
Date registered: Sep 2008
Vehicle: 2001 E55 AMG
AWD777 - You literally removed the cluster without taking the dash apart at all?
Kevin
2001 E55 AMG
klwhitacre is offline   Reply With Quote
Old 09-10-2008, 06:17 PM   #32 (permalink)
ohlord's Avatar
Cluster
just pulls out with the cluster hooks,no need to pull the dash apart.
I have the cluster hook and radio/climate control key set $32 delivered.
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz
My friends all drive Porsches
I must make amends
Worked hard all my lifetime
no help from my friends
So Lord, won't you buy me
a Mercedes Benz"
That's it
"The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over."
ohlord
Old 09-13-2008, 11:37 PM   #33 (permalink)
klwhitacre's Avatar
ohlord - would you recommend unhooking the battery before removal? I will need to track down the stereo code (good luck), or it's going to be really quiet in there when I'm done! Too bad there's no way to get the stereo to tell you the code...
Old 09-14-2008, 12:33 AM   #34 (permalink)
ohlord's Avatar
Yes
always and then if testing system to make sure ribbon is connected you can juice it up again.Radio code if oem radio call dealer or some make you come in with your papers and vin to show it is yours.
nav systems don't need codes.
resync windows after battery disconnect and recenter the steering wheel yaw sensor.
ohlord
Old 09-18-2008, 11:42 AM   #35 (permalink)
Date registered: Jun 2008
Vehicle: 1998 E320 on 18's
Dim Temp Reading
I was hoping someone would reply to Robrelish's question...
I also have a very dim outside temperature reading. I can read it dimmly at night (All of the pixels are there) and in the day if the shadows are just right.
It seems like just a "back lighting" bulb may be bad?
I have never noticed an incomplete number or symblol. Just very dim...
If I pull the cluster and replace all of the bulbs will the problem be resolved?
Thanks for any help.
CWood is offline   Reply With Quote
Old 09-18-2008, 11:57 AM   #36 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Your problem does sound like a lamp gone bad.
