Old 02-07-2005, 02:31 AM   #1 (permalink)
Kyastas's Avatar
Date registered: Sep 2004
Vehicle: 1997 E420
please help with amg monoblock
I have 97 E420, and looking at amg aero 2 monoblock. the problem is those wheels came off sl class. the tire size is Pirelli Supersport 245/40/ZR18 on the front and 275/35/ZR18 in the rear. tire rack recomending 235/40-18 on front and 265/35-18... do you guys think it will fit to my car, or I need to do somethink....
Thanks anyway
Kyastas is offline   Reply With Quote
Old 02-07-2005, 06:15 AM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: please help with amg monoblock
Check the off-set on those wheels to see if they are in the 30s. Those tires are going to be too large so you should drop down to the recommended sizes that you had listed to avoid rubbing.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 02-07-2005, 08:09 AM   #3 (permalink)
BANARAS BENZ's Avatar
Date registered: Nov 2004
Vehicle: W210 E300TD 1998
Hi,
I have AMG 18 Monoblock on my E class
When I brought the wheels, I had 235-45-18ZR at the front, those where rubbing against the arches, now I have 235-40-18ZR, which are perfect.
I suggest sticking with the suggested size.
BANARAS BENZ is offline   Reply With Quote
Old 02-07-2005, 12:43 PM   #4 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Date registered: Jul 2004
Vehicle: SL, CLK & 5E's
E-Klasse is right (as usual). Though if your offset is between 30 & 40 you should be ok since the rolling radius of ones you are refering to is only a few percent larger (up to 2.5% deviation from original is acceptable).
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/41571.gif"border=0>
<img src="http://www.danasoft.com/vipersig.jpg">
Storm. is offline   Reply With Quote
Old 02-07-2005, 02:58 PM   #5 (permalink)
Kyastas's Avatar
Vehicle: 1997 E420
Thanks you are best
Old 02-07-2005, 03:23 PM   #6 (permalink)
Fast55's Avatar
Date registered: Oct 2004
Vehicle: 2006 E55, 2005 SLK55, a few others
The 275's will be fine on the rear, the fronts will be too large as suggested.
Fast55 is offline   Reply With Quote
