Old 12-11-2006, 05:57 AM   #11 (permalink)
Date registered: Dec 2006
Vehicle: 2001 E320
The battery on my '01 E320 got low/dry, and before I took it out to service and charge, I hooked my jumper battery pack onto the underhood jumpstart points. When the battery was ready I re-installed and didn't have to reset anything. Just be careful with the positive terminal when it's disconnected. I put mine inside a heavy leather glove.
Amnicola1 is offline   Reply With Quote
Old 08-17-2007, 10:23 AM   #12 (permalink)
Date registered: Aug 2007
Question my car doens't work - no electricity
hi!
It was everything ok. although I had had a malfunction in lights system, for 1 month.
However, yesterday, I parked my car and then returned back after 5 minutes to re-start it, but as I turned the electronic key (switched on) , lights turned on and then suddenly all the electricity gone.
Now, I can not even turn the electronic key to other level, say, it is locked and doesn't allow the key to be be switched !
Any reply will be really appreciated.
benzcool is offline   Reply With Quote
Old 08-23-2007, 05:49 AM   #13 (permalink)
Vehicle: MB E270 CDI , 2001
Thumbs up
Hi. I had the same issue one month ago. One of my car keys went dead from one they to the other. I was still able yo lock/unlock the car but nothing at all happend when inserting the key in the ignitionlock. I tried my other key and that one was still good. Contacted my local Mercedes store and the only solution was to order a brand new key.......
Vipert is offline   Reply With Quote
Old 01-29-2008, 04:37 PM   #14 (permalink)
E430SportMB's Avatar
Date registered: Dec 2007
Vehicle: 2000 MB
Great information . Thanks .
E430SportMB is offline   Reply With Quote
Old 07-31-2008, 11:47 AM   #15 (permalink)
Date registered: Jul 2008
Vehicle: E320 1999
Thanks that is great info. My cruise control stopped working when I did battery disconnect (change). Is there anything that you know of that I may have to do to get it working again?
tgkilburn is offline   Reply With Quote
Old 10-18-2008, 09:40 AM   #16 (permalink)
Premium Member
Date registered: Aug 2008
Premium Member
So far after disconnecting the battery all is reset except the widows. They go down but only go up after continually pressing the button. Then they go up in small increments. Any suggestions? I was attempting to reset the malfunction display after disconnecting the battery to get rid of a suspected faulty CEL. The CEL went out an I then got a MFD of Antiskid and brake control malfunction. Any ideas in ridding that?
keywasted is offline   Reply With Quote
Old 10-18-2008, 11:47 AM   #17 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Get the window all the way closed, then hold the switch in the closing position for several seconds. For the anti-skid malfunction, try turning the steering lock-to-lock several times.
