Old 01-12-2005, 10:42 AM   #1 (permalink)
Bio
Bio's Avatar
Date registered: Dec 2004
Vehicle: 1997 E320
Catalytic Converters
I've notice more and more a strong odor coming from my exhaust. People have mentioned it may be the catalytic converter. Does anyone have any thoughts or experience with this?
Thanks Bio
Bio is offline   Reply With Quote
Old 01-12-2005, 11:26 AM   #2 (permalink)
spine911's Avatar
Date registered: Oct 2004
RE: Catalytic Converters
I dont think so,odor is not an indicator of a failing/failed Cat. If the Cats are bad most likely your Check Engine Light will come up, power loss/limp mode in some cases.... A simple way to test your Cats would be to: 1:Listen to the Cats upon startup or acceleration,- if it rattles excessively/"marbles in a can" sound- it is broken. 2: Tap the Cats using a small hammer, if you hear the "marbles in a can" sound- it is broken[:D]....The rattling sound is caused by the broken Ceramic internal pieces inside the Cat.
spine911 is offline   Reply With Quote
Old 01-12-2005, 07:32 PM   #3 (permalink)
Sandro N's Avatar
Date registered: Feb 2004
Vehicle: Hooked up 96 E320
You know bio, a few weeks ago I did an exhaust system on mine and I noticed that the piping before the cat's had developed a hole in the tops of the pipes. Sometimes when I leave the door open while the engine is running I'll notice a heavy odor of exhaust gasses, maybe thats what your smelling.
(Side note: does anyone know if those holes could eventually pose a problem.)[?]
sandro natale
Sandro N is offline   Reply With Quote
Old 01-12-2005, 09:29 PM   #4 (permalink)
spine911's Avatar
Sandro N - 1/12/2005 9:32 PM
Nothing to worry about an Exhaust Leak. Youll just experience a distinct increased exhaust noise. BTW, another definitive Cat. test would be a Pressure test. Just bring your car to any Muffler Shop, they will take off the 02 sensor/s and test the Cat. for back pressure.
Old 01-14-2005, 07:05 PM   #5 (permalink)
Bio
Bio's Avatar
Vehicle: 1997 E320
Thanks for the replys, considering the price of a cat. I'm glad to hear that it may be something else spine911. I'll check the exhaust Sandro. I'm sure it's original. Thanks for the input.
Bio
