"Brake Lining Wear" - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-02-2005, 03:28 PM Thread Starter
jtorre1's Avatar
Date registered: Jan 2005
Vehicle: 2007 E350 4MATIC
Send a message via MSN to jtorre1
"Brake Lining Wear"
I have a 1999 E320 and last night a message appeared on my dash that reads "Brake Lining Wear". What exactly does that mean because I went to my owner's manual and it doesn't cross reference that warning message anywhere. Also how grave is this warning and what is the next step?
Thanks in advance.
James
jtorre1 is offline
post #2 of 4 (permalink) Old 01-02-2005, 05:06 PM
Vehicle: ML550, W212 E350 4 matic, 1966 Corvette C2 convt.
RE: "Brake Lining Wear"
Believe it means that your brake pads are worn and should be replaced shortly
sosh is offline
post #3 of 4 (permalink) Old 01-05-2005, 07:10 PM
Vehicle: 1996 E320
You have about 2-3MM left on the pads. That equals about 2-3 months left.
gmacosta is offline
post #4 of 4 (permalink) Old 01-05-2005, 09:22 PM
Storm's Avatar
Date registered: Jan 2004
Though it may sound odd, the 210's brakes were designed in such a stupud way that when you change the pads you should also change the discs. I tend to change my discs every 2 times I change my pads, as they (discs) tend ot wear pretty fast and cant be remachied (incorrect heat dissipation).
Storm is offline
