Old 12-15-2004, 01:02 PM   #1 (permalink)
Bio
Bio's Avatar
Date registered: Dec 2004
Vehicle: 1997 E320
Center Brake Light
Looking for a good fix for the center brake light, short of hard wiring it. I've done the sanding/filing of the contacts thing, but after a short period of time I find myself doing it again. On the same subject has anyone tried using an LED bulb? Thanks
Bio is offline   Reply With Quote
Old 12-16-2004, 09:56 AM   #2 (permalink)
Date registered: Jul 2004
Vehicle: 1999 E320 Wagon demoted to parts car
RE: Center Brake Light
LED bulbs will, most likely, register as a "lamp malfunction".
E Wagon is offline   Reply With Quote
Old 12-16-2004, 10:38 AM   #3 (permalink)
Date registered: Jan 2004
I was under the impression that the center brake lamp would not display lamp defective msg. I know E class upgraded his brake light to a 00+ led and didnt have any problems.
Shane C is offline   Reply With Quote
Old 12-16-2004, 12:43 PM   #4 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Vehicle: SL, CLK & 5E's
The LED strip came in 1998 (late). If you change your rear shelf to the later model you will not have a problem.
However if you just want to add LED bulbs to your older 3rd brake light you will definitly get a "bulb faliure/defective" message. you will have to add a resistor to the wiring so that the urrent draw remains stable after changing to the more efficiend LED bulb.
Instead of constantly sanding the contacts try adding some conductive grease to the points ( i think copper grease works). Ask your local hardware store for the grease which is used in home dimmer switches.
Good luck.
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/41571.gif"border=0>
<img src="http://www.danasoft.com/vipersig.jpg">
Storm. is offline   Reply With Quote
Old 12-16-2004, 02:54 PM   #5 (permalink)
Yeah I agree I would not put just a led bulb but rather a led strip! I have been looking for a strip to retro into my car since 99+ shelf is so hard to come by.
Old 12-16-2004, 05:43 PM   #6 (permalink)
gerden's Avatar
Date registered: Aug 2004
On this subject, MineS a '98 E300td.
cENTRE bRAKE LIGHT HASNT WORKED SINCE i GOT THE CAR 6 MONTHS AGO(sorry caps lock)but it doesnt bring up a malfunction light. The bulb looks OK. Is this simply likely to be a contacts problem?
gerden is offline   Reply With Quote
Old 12-16-2004, 07:58 PM   #7 (permalink)
Bio
Bio's Avatar
Vehicle: 1997 E320
Thanks for the info. As for the defective lamp message. I have received that on a side lamp (replaced), but never for the ctr brake lamp. I like the idea of the contact gease. Like to keep it simple until weather is better.
Old 02-23-2007, 03:20 PM   #8 (permalink)
Date registered: Aug 2006
Vehicle: Mercedes Benz E-230 P reg 1997
Exclamation re centre break light
i have the same problem
changed the bulb and took the whole copmartment out tested ok
but there is no power to the poles as there is no malfunction signal comming up
any suggestion on where is the other end of the cable is where else should i check
anmar75 is offline   Reply With Quote
Old 02-23-2007, 06:12 PM   #9 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
The owner's manual for my '96 says that the center brake lamp is not monitored.
