Old 11-24-2004, 11:43 PM   #1 (permalink)
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 00 E320
Is There Any Consensus on the Right HID or Xenon Kit?
I am contemplating the expense and frustration of ripping out perfectly good headlights in order to improve the kool factor on my 00 W210 as well as improve night time visibility.
Everything I've read on the In-Pro kits give me pause, and they are (only) a projector mod with clear lenses -- no Xenon, no HID. The Depos sounded no better.
Am I better off just bagging the idea at this time and getting whatever passes for the best halogens on the street right now? Osram-Sylvania? Philips?
Or maybe it's worth the factory kit (does someone have these?) I have a 2000 which is a slightly different front end (as you know) than the pre-2000's that I've seen with the In-Pro kits....
What's the current thinking on this?
Thanks
Mike
Now: 2000 E320, Then: 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline   Reply With Quote
Old 11-25-2004, 10:20 AM   #2 (permalink)
Date registered: Jul 2004
Vehicle: 1999 E320 Wagon demoted to parts car
RE: Is There Any Consensus on the Right HID or Xenon Kit?
InPro/Depo have two different sets of headlights. One for 96-99 and the other for 2000 onward. Depo now makes a HID ready assembly, for those who want to upgrade or have factory HID.
Technically anything with xenon gas is a xenon light; in marketing terms. However, All HIDs are arc types wether they are xenon, sodium, mercury vapor, or halide gas. Xenon HIDs in cars seem to be refered to as "Bi-Xenons" by the manfacturers.
It also appears that the InPro/Depo will NOT improve nighttime illumination unless you replace the internal lenses with w211 factory lenses.
I have used silverstars in my head and fog lights and they were wonderfull. Silverstars and blue visions have the same advisertised color temp: 4000k.
Do a search on silverstar, xenon, or blue vision. There are many threads here devoted to this topic.
E Wagon is offline   Reply With Quote
