Old 11-21-2004, 12:25 PM   #1 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Date registered: Jul 2004
Vehicle: SL, CLK & 5E's
Command in a 98??
I have been searching the W210 archives and i cant seem to get any decent info as to how to fit a command into a 98 210, and what parts are needed to make it work.
A step by step guide would be ideal, but any info is welcome as I'm seriously thinking on going all the way with my E280.
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/41571.gif"border=0>
<img src="http://www.danasoft.com/vipersig.jpg">
Storm. is offline   Reply With Quote
Old 11-21-2004, 01:33 PM   #2 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
RE: Command in a 98??
Please note that it is a Late 98, currently using an Audio 30 w/ CD changer.
After fitting the command, would it be possible to hook up a phone in the car as well, which would work with the command? (I know I would obviously have to fit a mic near the rear view mirror)
Old 11-21-2004, 01:43 PM   #3 (permalink)
Date registered: Aug 2004
Comand retrofit in a 1998 W210 is possible. You can purchase complete self installation kits from steve@mbenznl.com.
Since your car is a Euro spec, it requires more parts and more time to get a phone kit installed compared to the US spec cars - which come prewired. The microphone is one thing you need to add... I don't know exactly what else is needed for the phone install, but maybe someone else can help you with that.
Greetingz,
BigSis
BigSis is offline   Reply With Quote
Old 11-21-2004, 01:44 PM   #4 (permalink)
BTW, your CD changer will probably not work with the comand unit!
Greetingz,
BigSis
Old 11-21-2004, 02:30 PM   #5 (permalink)
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
BigSis - 11/21/2004 3:43 PM
Greetingz,
BigSis
Phone Kit (may as well be the UHI version)
Fibre optic cable from new CD changer
Rear trunk brackets
Controller (PSE)
Compensator
Antenna (with GPS)
Body cabling
Armrest cabling
Phone shelf in armrest
Would probably also benefit from pushbutton steering wheel upgrade and new instrument cluster.
Modz ... enjoy the difference. www.benzmodz.com
miroj is offline   Reply With Quote
Old 11-22-2004, 11:18 AM   #6 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Thanks guys I'll follow up on your advise, and keep you all posted on what transpires.
Thanks for taking the time to help out a (desperate)fellow member.
Easy[8D]
