Old 11-05-2004, 12:01 PM   #1 (permalink)
spine911's Avatar
Date registered: Oct 2004
anyone upgraded the 96-99 cluster to the 00-03 instrument cluster? will it work??
spine911 is offline   Reply With Quote
Old 11-05-2004, 03:19 PM   #2 (permalink)
JTA00R1's Avatar
Date registered: Sep 2002
RE: anyone upgraded the 96-99 cluster to the 00-03 instrument cluster? will it work??
yes it will work, but you will not get the steering wheel fuctions like the later years nor can you set the clock. [:)][:)]
JTA00R1 is offline   Reply With Quote
Old 11-05-2004, 05:22 PM   #3 (permalink)
spine911's Avatar
i have a 99e320, So, you mean to tell me everything will work except for the clock?
Old 11-05-2004, 05:35 PM   #4 (permalink)
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
JTA00R1 - 11/5/2004 5:19 PM
Why wouldnt the steering wheel functions work ... all you need is the correct parts and some skill.
Modz ... enjoy the difference. www.benzmodz.com
miroj is offline   Reply With Quote
Old 11-05-2004, 08:57 PM   #5 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Date registered: Jul 2004
Vehicle: SL, CLK & 5E's
miroj - 11/6/2004 12:35 AM
Time, Money & Skill,... three things I don't have[;)][:D]
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/41571.gif"border=0>
<img src="http://www.danasoft.com/vipersig.jpg">
Storm. is offline   Reply With Quote
Old 11-06-2004, 11:41 AM   #6 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
Install the correct Steering wheel.
You Will Need the correct contact ring and Some Wiring
Done...But It can be Done
Contact Steve @Mbenz.nl
Mark Cummins is offline   Reply With Quote
Old 11-06-2004, 02:00 PM   #7 (permalink)
JTA00R1's Avatar
yes everything will work as it should, but again you can not set the clock. A way to get around the clock is when you install the cluster wait until 12:00 to do so whether it be noon or midnight because once there is power to the cluster it will default the clock to 12:00 and start from that time. In regards to everything people are saying about the steering wheel controls, yes its possible but then you need to a ton of other parts like a newer style steering wheel. And the know how with alot of patience.If you are willing than great but some of us just like the look of a new cluster with out all the work.[:)]
Old 11-07-2004, 12:00 PM   #8 (permalink)
Date registered: Aug 2004
Retrofitting a multifunctional instrument cluster AND a multifunctional steering wheel is doable, in W210s which have been built AFTER February 1997; Steve MBenzNL did it lots of times in the past.
And as far as I know: there are no difficulties with the clock settings...
Greetingz,
BigSis
BigSis is offline   Reply With Quote
Old 11-12-2004, 05:24 PM   #9 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
Dont for get that US law is in effect on "truth in mileage", on the odometer. You will have to certify the mileage, and if you can not, watch the value of your car drop. When dealers replace a panel the parts depot codes the current mileage into it, when the dealer certifies the odometer.
Peter Guenther is offline   Reply With Quote
