Old 09-15-2004, 08:52 AM   #1 (permalink)
Date registered: May 2004
Send a message via AIM to aboniadi
Mercedes just can't stop giving problems, can it? lol
My driver's side back window on my 2000 E320 doesn't work. I opened the door panel and discovered that the barbed wire that pulls the window up/down was bent and was getting caught underneath the motor. So I need to buy a new barbed wire (prob from dealer). I was wondering if anybody has had to deal with this same problem of mine and if they had any luck.
Is it possible for me to hook the barbed wire onto the plastic rolls or do I need to have some kind of "specialist" do it. Thanks for any help guys.
Andre Boniadi
aboniadi is offline   Reply With Quote
Old 09-15-2004, 10:38 AM   #2 (permalink)
Date registered: Jul 2004
Vehicle: 1999 E320 Wagon demoted to parts car
RE: Mercedes just can't stop giving problems, can it? lol
Do a fourm search for "window regulator" to find the procedure.
If the cable sliped off the pully you might get by with just putting it back on. you might still have to drill out the rivits to remove the regulator. Otherwise, you will need a new regulator ($80 USD).
I believe some people have had the window fall and break when their regulator went so be carefull. I shoved a 1x4x24 inch piece of wood into my door to hold the window up untill I got the regulator fixed.
E Wagon is offline   Reply With Quote
Old 09-15-2004, 10:40 AM   #3 (permalink)
phaedrus_242's Avatar
Date registered: Sep 2004
Vehicle: '04 G35 Coupe 6MT
You are going to need a new window regulator assembly. The wire is not available seperately, and obviously something about the regulator caused that wire to fail. It's pretty simple to swap out, but you'll need to drill out the rivets holding it in. You'll need a rivet gun to reinstall the new one.
Sorry for the redundancy. There was no response while I was typing.,..
'06 E350
'04 Infinity G35 6MT (Traded 4/06)
'97 C 230 (Traded 12/04)
'02 CLK 55 (RIP 8/04)
phaedrus_242 is offline   Reply With Quote
Old 09-15-2004, 03:32 PM   #4 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
You need this part.
It is not barbed wire but steal cable. It will either break or get stuck around the plastic pully eventually.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
