Old 08-30-2004, 07:36 PM   #1 (permalink)
Date registered: May 2004
Removing Door Panel?
What is the procedure for removing the driverside door panel? I need to replace the seat switch.
Thanks
Bruce
dunga is offline   Reply With Quote
Old 08-31-2004, 08:13 AM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: Removing Door Panel?
The seat controls are held in with plastic clips that go through holes in the inner door panel.
Do a search on mb world for door panel removal.
There are a couple of hidden screws and some plastic clips and the door panel lifts up and off.
Remove the lock pin in the uper right corner. it just unscrews.
Pop the SRS cover and the cover below the door handle.
Flip the black cover off under the chrome door handle.
Unscrew the bolt holding the latch cover on.
Unscrew all of the screws that are under all of the covers that you removed.
Pop all of the plastic clips around the outer part of the panel. Be careful not to break them off.
Swing the door panel out at the bottom and unplug the sill light in the bottom.
Lift the panel up to pop the rail that hold the top of the door next to the window.
Unplug the power seat controls.
Don't worry about the airbag. Only the cover is in the door panel. It is mounted in the door.
There should still be a plastic liner covering the inner part of the door to keep water out.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 08-31-2004, 10:12 PM   #3 (permalink)
Thanks for the help[:)]
