The leather on my steering wheel is rotting away. rather then pay the dealer price, I've been shopping elsewhere. Does anyone know any other years or models that will interchange with a 98 E300?
The airbags are all the same, make sure you use your original one though.
Best advice is to remove the battery terminals before you start your work (just to be on the safe side). On the back/under side of the steering wheel you will find a few TX screws (T-25H or T-27H can't remember). Open them to remove the airbag, then just unclip the (if memory serves correct) yellow clip and remove the airbag. The steering is attached to the rod with a single nut. Dont worry about centering the new wheel because there are marks which will indicate the centre (0) point.
Then all you have to do is attach the clip to the airbag, refit the screws and attach the battery cables.
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: w210 steering wheel interchange
If you exchange the airbag too, you have more selection. You can swap the steering wheel and airbag from the SLK for example for a different look.
You can even move it to the other side of the car with the right parts...[:D]
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
