Old 08-26-2004, 08:49 PM   #1 (permalink)
Date registered: Aug 2004
99 E300 TD - turn signal and cruise control lever is loose
They both work, but they are loose - there's some sort of plastic collar that goes around the steering column, and it has about an inch of play in it, up and down.
Is this normal? If it isn't, how do I go about getting it fixed? I got warranty coverage for this car, so I can take it back to the dealer without it costing me too much.
olynn is offline   Reply With Quote
Old 08-26-2004, 09:08 PM   #2 (permalink)
Date registered: Dec 2003
RE: 99 E300 TD - turn signal and cruise control lever is loose
Let me know what they tell you. Mine does the same thing.
E300POS is offline   Reply With Quote
Old 08-30-2004, 06:28 AM   #3 (permalink)
gerden's Avatar
My 98E300TD multifunction switch & stalk are quite rigid. Dont let them tell you that this is normal.
gerden is offline   Reply With Quote
Old 09-30-2004, 09:04 AM   #4 (permalink)
Date registered: Jun 2003
Vehicle: 98 E430 sport
My 98 E430 had the same problem. I took it to the dealer. They said it needed a pin to hold the collar in place. They put it in at no charge.
gtbest is offline   Reply With Quote
