» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Closed Thread
Old 09-14-2004, 08:39 AM   #31 (permalink)
Ruffrob's Avatar
Date registered: Jan 2004
Vehicle: 2003 Obsidian Black E320
Send a message via AIM to Ruffrob Send a message via Yahoo to Ruffrob
RE: W210 Headlight Removal?
Originally posted by Storm
But I warn you, everyone out there is sick to death with the pathetic delivery of In-Pro.
If you don't believe Storm,read here
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1173736&start=1&fid=6
1997 Black E320
1994 Black Acura Legend L (gone,but not forgotten)
Ruffrob is offline
Old 09-18-2004, 12:19 AM   #32 (permalink)
Date registered: Sep 2004
Vehicle: 1999 E320 62,000 miles & counting
Wow.... the clear housing look great. I was thinking about replacing mine too. But Ruffrob's experience scared me a little.
Take your pick,they all seem to have the same price point,however,i would have them siliconed all the way around the seal since they're notorious for having a leak there,and if you read the other posts from us on these,you'll see the water(condensation) in the lens right after
My questions is.... Is this problem common to ALL after market clear light housing? If I get the one make by in-pro, will it have the same problem? Any experiences guys?
Thanks for the tip.
dn54168 is offline
Old 09-18-2004, 05:45 AM   #33 (permalink)
Ruffrob's Avatar
Don't be scuurred......[:D]. The shop where I got mine put in,was where I saw one of the installer's cars (A Honda Civic). It was really wet on the inside,but he never 'siliconed' it,so every time he went to the car wash,or it rained.....See my other response to you..
Ruffrob is offline
Old 09-20-2004, 05:23 AM   #34 (permalink)
Storm's Avatar
Vehicle: 129, 209, 219, W221 & 4E's
My inpro's don't leak and have a perfect seal of silicone all round.
As you can see, ruffrob and I have purchased from two different companies but in the end result is the same. (He fit his better than my first attempt)[B)] - since rectified
Just use a little care and you'll be fine.
Good Luck[8D]
This used to be me http://www.benzworld.org/forums/21852-storm-.html
Storm is offline
Old 09-20-2004, 10:07 AM   #35 (permalink)
Ruffrob's Avatar
Not exactly,Storm,I know I posted somewhere about the fact that the driver's side had to be sealed,but it's all good now.
Ruffrob is offline
Old 07-21-2005, 03:06 AM   #36 (permalink)
Storm's Avatar
You got me ruffrob, mine leaked today[B)]
I've got mist on the left side[:(!][:(!]
Storm is offline
Old 07-21-2005, 10:38 AM   #37 (permalink)
Ruffrob's Avatar
So,my brother,whatcha gonna do???
Ruffrob is offline
Old 07-21-2005, 10:45 AM   #38 (permalink)
zam2000's Avatar
Vehicle: W220
Most Depo light need to be seal with high quality silicon II, 2 or 3 layers, prior to being installed into car.
I do that for all light to my customers. For the 96-99, at least it's not that since the bumper doesn't have to go to install the light. For face-lift 2000-later, it's PITA to take out light
Ruffrob - 7/21/2005 12:38 PM
zam2000 is offline
Old 07-21-2005, 11:50 PM   #39 (permalink)
Storm's Avatar
Ruffrob - 7/21/2005 5:38 PM
Follow your advice and remove them and seal them with something serious[;)]. How I wish I had taken your advice earlier.....[xx(]
I have left this thread intact so people don't make the same mistake as I did.
Storm is offline
Old 10-03-2005, 08:05 AM   #40 (permalink)
raymond-'s Avatar
Vehicle: 99 E320 Depo/E55bix, clear fogs, E55 rims/tails/seats, Audio10, BilsteinSport, cut springs
A caution for folks opening up their headlight shell.
When assembling, and you use acid 'stinky' smelling silicone, allowing the fumes to build up, eg within
the headlight enclosure may cause some discoloration
or faint fogging up of the clear plastic.
So when I read the Zam's advice to apply 2-3 beads of
silicone, I thought that I needed to append this
tip out there as well.
If you can use RTV non-stinky, great. I wish I had
enough smarts to figure out what makes it stink vs not,
and give better pointer, but I'm not to brite. So....
if, upon applying the silicone sealant and your nose
wrinkles from the sharp smell, run a small fan and
nearby. Aim direct and keep the fumes from remaining
stagnant around the headlight assembly. It should be
fine then, I surmise.
raymond-
47º34'N 122º18'W
raymond- is offline
Closed Thread
