Old 08-24-2004, 07:15 AM   #1 (permalink)
Date registered: May 2004
Send a message via AIM to philly
18" Rims & Tires
I have silly q. What is the right (ET) offset
should be for 18" x 8.5 rims which will fit w210 for a nice ride. How about tires? Any suggestions?
Thank you!
philly is offline   Reply With Quote
Old 08-24-2004, 03:40 PM   #2 (permalink)
Date registered: Jul 2004
RE: 18" Rims & Tires
The right et for the car is 35mm and if you want to keep the tire of the same diameter you should go 235/40/18 you can also go 245, it makes very little difference in the diameter.
[:)]Regards
rupert is offline   Reply With Quote
Old 08-24-2004, 04:11 PM   #3 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
You can go higher in the back, like 265/35 and have a 235/40 in front. Mine are 18x8 ET32 in front and 18x9 ET35 in back.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 08-24-2004, 05:08 PM   #4 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Vehicle: SL, CLK & 5E's
I went 235/40 on the front with 8.5x18 with ET31 and 265/35 on the rear with 9.5x18 with ET35. No rubbing and no grinding needed.
Like E-Klasse said you CAN go 265 on the back, my other (AMG) 210 came with that setup from the factory but on 8x18 (front) & 9x18 (rear).
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/41571.gif"border=0>
<img src="http://www.danasoft.com/vipersig.jpg">
Storm. is offline   Reply With Quote
Old 08-25-2004, 09:28 PM   #5 (permalink)
Thank you so much for your reply!
Old 08-29-2004, 07:24 AM   #6 (permalink)
Date registered: Mar 2003
Vehicle: 1999 W210 E320
will 19s fit? [:D]
Protect the body, ignite the soul.
My Heritage.
freshyip is offline   Reply With Quote
Old 08-30-2004, 04:29 AM   #7 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Yeah they will, but I wouldn't reccommend it due to the harsh ride, and rubbing issues.
Old 09-02-2004, 12:23 AM   #8 (permalink)
Date registered: Feb 2003
Vehicle: 2001 e320 sport
i have 18x8 et 35 offset with 245/40/18 all around and because my front fender is not rolled they rub in the front on any medium size or above bump.
the ride is great though and the look is even better
chrisd56 is offline   Reply With Quote
